Old 06-13-2009, 10:34 AM   #1
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
sofa sleeper in 25FB
want to replace the bed in 2008 safari FB with leather sleeper sofa----- any one done this and can it be done...physically can sofa be put into coach???? most of them are 39 or 40 inches wide and 80 or 86inches long
and then want to remodel bathroom/shower area by replacing current shower stall with a complete alumunim covering and then put permanent door between kitchen area and front of coach...any thoughts...
sea shores
kingfisher24 is offline   Reply With Quote
Old 06-13-2009, 11:05 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Are you going to be traveling with this combination? Or just stationary in a campground? What is your tow vehicle? Can you fit a normal sofa sleeper in there with the curbside storage compartment? I'm sure you have a plan for moving the Parallax converter somewhere. Is there really enough long flat wall to fit a sofa sleeper up against? For the weight involved, it had better be on the centerline.
Airstream's weight conserving furnishings are relatively light. We've all moved sofa sleepers and have experienced how very heavy they are. This will significantly increase the tongue weight. Looking at airstream.com it does show your net carrying capacity to be around 1800 pounds. All of us find reason to travel on occasion to the next stop with a full water tank. A heavy fixture like this will develop a lot of inertia over road bumps and potholes. Attachment to the trailer structure will be an issue.
Will a commercial couch fit between the fridge and pantry? No worry about that. Everything you see inside your Safari came through the door -- I don't think an intact commercial couch will do that.
5 meter Langford Nahanni
Safari C 6-sleeper needs new owners RT Livingsto Trailer Values 1 03-31-2009 03:57 PM
Replacement sleeper sofa for a '79 Safari jeftec Cabinets, Counter Tops & Furnishings 1 08-05-2008 06:44 PM
Saw '03 6 Sleeper - Houston $25k Bob Thompson Dollars & Cents 0 05-31-2006 08:16 PM
Sofa/Sleeper replacement 69Ambassador Upholstery, Blinds, Walls & Interior Finishes 0 02-21-2004 07:00 PM
25C 6 sleeper black tank Melvin P. Thorpe 2000 - 2004 Safari 15 10-14-2003 05:27 PM
