11-21-2013, 01:11 PM
1968 17' Caravel
Jackson Heights
, New York
Crypton for Upholstry and Curtains?
Hi Folks,
In the process of restoring a 68 Caravel.
After doing some research here and elsewhere I came across Crypton Fabric.
Two questions regarding this fabric
1. Is this a durable and stain resistant product for upholstery in a trailer and well liked?
2. Can this fabric be used for curtains as well?
If there are any other preferred fabrics please make a mention of them as well.
11-21-2013, 03:24 PM
1977 Argosy 24
Milltown
, Wisconsin
Isn't that the planet that Superman came from?
11-21-2013, 03:35 PM
Ottawa
, ON
That one is spelled with a "k".
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
Alamo Heights
Hence their "superfabric" product.
It looks pretty interesting, I'll be following this to see if there is any feedback. I'll have a gaucho to reupholster pretty soon, and the wall-pads that keep you from brushing up against the cold walls in bed.
— David
11-21-2013, 07:03 PM
2000 19' Bambi
mt. Prospect
I ordered some Crypton fabric to test, and covered a small bench with it, with piping around the edge. The hope was that it might prove "cat proof", and the results are very good. It's proving very durable. It is designed for outdoor furniture, so it is water resistant, but the fabric is a touch abrasive. Still, i'm going to recover my dinette cushions with it in the spring.
Crypton is $30-40 a yard, but here is where you can buy large remnants for $10-12/yd
1-10 Yard Crypton® Fabric Remnants
11-21-2013, 08:30 PM
1967 22' Safari
MILAN
Fantastic!
I had just spoken to the wife yesterday about material for the covers on the dinette & goucho and wall pads for the "Landshark". I will be taking a look at this source to see if we can use this fabric. I will be watching this thread for further posts. Thanks, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
11-21-2013, 09:27 PM
1964 26' Overlander
1964 19' Globetrotter
OlyPen
I used Crypton fabric last time around with awesome results.
Crypton is a treatment that is applied to fabric to make it suitable for hard use and heavy cleaning. Crypton is the brand name of the treatment and while crypton fabric can be stain and may not shed wet stuff the way you expect, it can be cleaned with heavy cleaners, steam and abrasion with out damaging the fabric. It's used in healthcare settings, commercial applications and other high use areas. Highly recommended!
11-22-2013, 09:20 AM
1966 26' Overlander
Woodstock
, Georgia
that looks like great stuff
01-08-2014, 09:02 AM
Rot-Roo Rastro!!
2020 30' Flying Cloud
Austin
Just had our cushions recovered with a CF Stinson cryton fabric. I believe these folks make the Crypton fabric mentioned in this thread (as well as Sunbrella). Their website is most informative as it provided fabric content and fabric data such as (but not limited to) on moisture barrier properties, fabric resistance, colorfastness, abrasion strength, tear strength, seam slippage and more.
You will pay for these great fabric qualities. I ended up paying $60/yard after an extensive search. The price drove me to investigate using two different types of fabric on the dinette: one for the cushions and another on the bench. If you look at some used Airstream pictures (for sale), they has done this on some of their trailers.
After handling the fabric it is thinner than the Airstream installed fabric and I like its texture better.
The fabric could be used as curtains but they will probably need to a cover across the back (because of the pattern on the back may be pretty ugly). This fabric would block more light than the white/off-white ones that come stock on the trailer.
Good luck.
Barry & Andrea
2020 Flying Cloud 30' ~ Silversled
2019 Chevy HD2500, 4X4, Crew Cab
AIR #12075
01-08-2014, 10:35 AM
Airstream - Other
Bosque Farms
, New Mexico
A long time ago, we had the VW beetle seats redone by a woman at the county airport. She used aircraft-grade material, and it held up very well. Presumably somewhat more fireproof, though I can't really vouch for that.
Lynn
ACI Big Red Number 21043
