Old 08-18-2011, 07:57 PM   #1
oh2bcarefree's Avatar
HOUSE SPRINGS , MO
Images: 48
Can the Zolatone be saved??
The PO of our trailer painted the inside a soft creamy yellow, however there is zolatone underneath. I'd like to try and remove the paint and expose the zolatone.
As a test, I started in the closet and tried Mostenbockers #5 which is supposed to remove latex paint - it did a fabulous job and I was so excited! BUT, it seems that everywhere except the closet PO used a primer before painting. Ugh!!! Now, the Mostenbockers is about useless at trying to remove the paint and primer.
I've searched lots of threads and found snip-its of comments but no real answers. Has anyone found a way to save zolatone and remove primer/paint? Power washing currently is not an option.
Thanks in advance!!
Tina
ID:	138079   Click image for larger version
Tina and Mike
1959 Avion e-20
oh2bcarefree is offline   Reply With Quote
Old 08-18-2011, 08:14 PM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Unfortunately, we ran into the same situation on our '56 Safari...that's why we re-Zolatoned it.
Check out my "It's a Girl!!!" thread around post #269 or so...
Shari
Old 08-19-2011, 07:14 AM   #3
HOUSE SPRINGS , MO
Images: 48
Thanks Shari!
I knew that was the case with you and I know you are very thorough in what you do! I was just hoping someone may have had success...
Thanks again!!!
Tina
Tina and Mike
1959 Avion e-20
Old 08-19-2011, 09:15 AM   #4
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
We also had latex over our Zolatone. We found some really great vintage decals under our latex paint while trying to scrape it. We tried everything to save them (and the zolatone) because we thought they were so cool! There was nothing we could do to save the Zolatone or decals.
We spent so much time and energy (and money) scraping paint. (I used chemical stripper at least 4 times on every panel... more on some panels.) If I "did it again" then I would probably gut the trailer, sandblast it, and repaint the walls with new Zolatone.
~Lynnetta
Someday'59 is offline   Reply With Quote
Bambi II Saved from Recycler! Becky B. 1964 Bambi II 603 04-03-2017 07:19 PM
Mint Condition 64 - Should I change anything? robwok 1960 - 1964 Overlander 122 11-03-2015 12:50 PM
1959 Overlander Resurrection submariner 1954 - 1959 Overlander 78 05-12-2013 08:20 AM
Another Aluminitis victim flygrrl Member Introductions 15 08-10-2011 07:22 PM
Lets Fix WBCCI Howard Lefkowitz WBCCI Forum 110 07-15-2011 02:55 PM
