06-23-2015, 01:45 PM
irving
is there a good place to put an powerplant on a as
Where would be a good place ro put a power plant on an airstream ? The tounge? Can it handle an extra 160 labs ?
06-23-2015, 05:14 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
For a time I had put a 12 volt generator I made in the spare tire well under the tongue.
A generator will fit here if a person can get the package down to ten or twelve inches tall.
06-23-2015, 05:29 PM
Biloxi
, Mississippi
Would like to see that, do you have any pictures?
MICHAEL
06-23-2015, 05:41 PM
1972 31' Sovereign
Benton
, Arkansas
06-23-2015, 05:46 PM
1972 31' Sovereign
Benton
, Arkansas
I was running it on propane, and it worked well, but the belt drive setup I had for driving the alternators was problematic so I pulled it off.
A 3500 watt A/C gen with the fuel tank removed would fit there pretty well.
I might try another one there someday.
06-24-2015, 06:07 AM
Biloxi
, Mississippi
Very cool. The ingenuity of Airstreamers never fails to amaze.
MICHAEL
06-24-2015, 07:57 AM
2020 Classic 33
Box Elder
, South Dakota
halftime just watch the overall tongue weight. If I remember correctly the AS is rated on the frame at a max of 1000#.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
06-24-2015, 12:06 PM
2012 23' FB International
Woodstock
, Ontario
Seems to me if you are going to go with such a small unit, why not buy a small Honda Generator and keep it in the truck bed. Weight of the unit can't be to much of deal to haul in and out and the vibration on the frame is a non-issue
JCW
06-24-2015, 12:16 PM
Vancouver
, British Columbia
Good details in this thread on withidl's custom installed Onan 4000. Start at post #18, lots of photos of the install later in the thread.
http://www.airforums.com/forums/f448...ors-68808.html
06-24-2015, 02:13 PM
1972 31' Sovereign
Chicago
AS trailer generator
I have installed a Generac 3.5KVA propane generator in a 1973 Sovereign 31ft. trailer. It is in the space in front of the trailer under the setee. I constructed a frame for it in the space where the spare tire would normally be mounted, then built a box out of 3/4 plywood lined with galvanized sheet metal to cover it. I lost two of the slide out trays in the process, but am happy with the tradeoff. The floor is cut so that air can enter for cooling and engine air intake. The exhaust exits under the propane tanks in the a- frame. I upgraded to 40 lb tanks. It is quiet enough to be comfortable with the air running and all of the other entertainment equipment.
This generator would not operate the orginal Armstrong AC unit. Though that unit worked ok with shore power, the 3.5KVA unit could not run it. I changed the AC to a newer unit and everything works fine. Seemed I was overdue for that.
06-24-2015, 02:59 PM
beaumont
amazing
This trailer is just amazing.. absolutely beautiful.
06-24-2015, 03:35 PM
irving
Originally Posted by jcl
goo info thanks
