Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 08-12-2004, 10:41 PM   #1
JohnG
JohnG's Avatar
Profile:
What Aluminum in 1975
Can anyone say for certain what kind of aluminum was used for the skin in 1975?
I have to replace the roadside lower panel that wraps from below the front wing window to the side of the trailer. Need to know for sectain what type aluminum was used. The service manual does not say, it just says .032 thickness and the size of the panel.
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-13-2004, 07:04 AM   #2
Happycampers
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough, , Ontario
John, I just replaced the same part on my Argosy except on the back. I just sniped a piece of the old stuff and went to the metal shop and told them I wanted something close to that size, it worked great, I don't think it really matters what size it is as long as it will bend well to conform to the curve, after it is on nobody knows how thick it is anyway. Marvin
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 08-13-2004, 07:30 AM   #3
JohnG
JohnG's Avatar
Profile:
Thanks Marvin, But I know how thick it is since the manual says it is .032
What I need to know is what type of aluminum I need. Like 2024-T3 Aluminum, which type was used in 1975?
I don't know for sure which type was used and I need to know cause after it is replaced I will be polishing the TT and I want the new area to look the same tone as the rest.
John G
Old 08-13-2004, 11:43 AM   #4
JohnG
JohnG's Avatar
Profile:
I wonder why AS dosen't have a technical specifications page on thier website, or do they and I have maybe missed it??? I really need to know which type of aluminum they used on the 75's so I can get it ordered.
John G
Old 08-13-2004, 12:31 PM   #5
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
John G.
The aluminum used for the 75 models was 2024T3.
All the side and roof sheet were .032 inches thick.
If your going to replace the lower side sheets, then change the thickness to .040, as Airstream has in the later models.
If will give the sheel a little extra strength.
Remember that the type construction is semi-monocouque, which means the shell is "load bearing."
That in it self, suggests beefing up the shell, if you change the lower side sheets.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 08-13-2004, 12:42 PM   #6
JohnG
JohnG's Avatar
Profile:
Andy,
Thanks for the info. I would have replaced with .032 so I am glad you pointed out what I should use and the type of aluminum too. I am placing a note in my Service Manual now.
John G
Old 08-13-2004, 03:13 PM   #7
markdoane
Profile:  , Minnesota
Images: 59
John G.
I guess I should have asked the question also. Just got my .032" for the lower side sheet today.
Non-contributing deadbeat.
Old 08-13-2004, 09:27 PM   #8
JohnG
JohnG's Avatar
Profile:
Don,
I'm no metallurgist, but I doubt that .008 difference would be all that critical in terms of strength. I think it goes to the old adage that when doing a repair it should be as strong as the original was and if possible it should be stronger.
At least your repair will be as strong as the original, and possibly stronger when you figure in the metal fatigue factor. There is probably a chart somewhere that will tell you how much stronger one size is over the other, but what I am saying is that I wouldn't sweat .008 in difference.
John G
Old 08-13-2004, 09:44 PM   #9
markdoane
Images: 59
Originally Posted by JohnG
Don,
Probably one reason they made the newer models with thicker metal was to compensate for lower tensile strength.
Old 2024-T3 has a yield strength of 45,000 psi
New 3004-H38 has a yield strength of 36,000 psi
belly pan aluminum? where? pinkflamingoes Belly Pans & Banana Wraps 33 11-03-2006 09:33 PM
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 5 09-24-2006 12:17 PM
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 34 02-24-2005 10:14 PM
463 inches Aluminum Curtain Tracks 4 Sale Cat Parts Archive 8 05-10-2004 01:56 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
test
