Rivet Shaver - I bought a US Industries Rivet Shaver added a foot piece and it cost me 50 dollars shipping and all on ebay. i just checked and there is one on there that is almost identical to mine right now. Just put "rivet shaver" in the search and it will show you what is available. I posted a picture from one that is on ebay right now so you can get an idea. I use the smaller shaver head and it works great. It is both fast and easy.
Rivet Gun - I use an Ingersol Rand regular air hammer and cut the air presurre down. The one I bought came from Harbor Freight
http://www.harborfreight.com/cpi/cta...unction=Search It is 10 dollars cheaper now than when I bought it, I paid 39 for it. The pressure regulator is there too
http://www.harborfreight.com/cpi/cta...emnumber=36797 I place it in the air line at the tool. It has the male end on one side and the female end on the other side this works so I can set the presurre anytime no matter where I am without having to go back to the compressor.
Pop-rivet Gun - Definately go with an air pop rivet gun. It sets the rivet fast and won't wear your hand out. You can go with one like Bobby pictured above, but I prefer the pistol type because they will get into a tighter area.
Obstruction Finder for use with Olympic Rivets - This is simple. Just take a coat hanger and cut a piece about 9 inches long. now bend one end into a small circle, next bend the other end at a 90 degree angle so it looks like a "L" Make the bend so it is about 1/4" longer than the Olympic Rivet set leg. To Use just hook it into a drilled hole, pull it back so the L end will be up against the inner wall and turn it. If it catchs something then you know you have an obstruction and can set the Olympic Rivet that you have trimmed so it has only 2 legs so that the missing leg of the rivet is facing the obstruction.
Aluminum Solid Rivets - Come in "A" and "AD" hardness. "A" is soft, made from 1100 grade aluminum and have a tensile strength of 16,000 PSI. "AD" is much harder and is also harder to set requiring more bucking. "AD" is made from 2117 aluminum and heat treated to T4 Specs and they have a tensile strength of 38,000 PSI. Airstream uses the softer "A" rivets on my model and most likely on your model too. You can always tell the harder "AD" rivet because it has what looks like a center punched hole (It is small) right in the center of the rivet head which the softer "A" rivet does not have.
Bucking Solid Rivets - Must have 2 people, a riveter and a catcher (the person on the inside) Always make sure the catcher is on the same rivet as you are before you buck it in. Just have them tap agaionst it so you know. If you buck against a rivet without the catcher being on it then the result will be a rivet dent in the panel. You must always apply pressure to the rivet through the rivet hammer or air hammer while riveting. This pressure must be firm so the bucking action of the tool dose not allow it to slip off the rivet head. Use short trigger squeezes until the rivet is set. Also the bucking bar dose not have to be one of those special tools that you see. It can be a small sledge hammer at least 1 pound. You just need something heavy to mushroom the inside part of the rivet while you set it.
Note> The difference between a rivet hammer and an air hammer is that the rivet hammer will hit slower. Instead of the Buck - Buck - Buck - Buck of an air hammer you will get a BucK - - Buck - - Buck with the river hammer. I have used both and don't really think that there is a big difference between them, and as I said you can turn down the air pressure and make the air hammer more controlable.
