09-19-2014, 05:28 PM
1967 24' Tradewind
Alameda
Rib length?
Hello,
So we're looking at the interior of the outside skin, and some of the ribs are shorter than others at the bottom end. Is that normal? I'm guessing it is, what are they for? Holding the shell shape, and I'm also thinking they are obviously for attaching the inner shell to. Just like the framing of a house. But I removed the belly pan years ago and I can't remember if these were normally different lengths or not. Here are pictures. I'd appreciate some input. Mmmm. Short ribs.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
09-19-2014, 05:34 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
That doesn't seem right to me. I just finished gutting a '72 Overlander @ Colin Hyde's shop a week ago and all of the vertical ribs went into the C-channel at the base of the outside skin. Seems to me that those structures would be required to keep the body securely on the frame. I'd consider riveting in some sort of rib "extensions" so that each rib is firmly attached to the C-channel.
Bob Martel
WBCCI# 5766
09-19-2014, 05:53 PM
Oswego
I seem to remember Andy saying is was normal on some older models. PM him and ask.
-Rich-
09-19-2014, 05:55 PM
1967 24' Tradewind
Alameda
Maybe they were attached to banana wrap?
~ Hurley
ingrid
09-19-2014, 05:56 PM
1967 24' Tradewind
Alameda
No forget that that would make no sense.
~ Hurley
ingrid
09-19-2014, 05:59 PM
1967 24' Tradewind
Alameda
What's Andy's user name?
~ Hurley
ingrid
09-19-2014, 06:02 PM
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs
, PA
I just took the interior walls off my 62 Safari and found a similar situation and then they added more rib. I'll get pics this weekend.
09-19-2014, 06:22 PM
1967 24' Tradewind
Alameda
Yes please. I'll try to figure out what the deal is in the meantime. If I can't get input I'll call The VAP!!
~ Hurley
ingrid
09-19-2014, 06:24 PM
Oswego
Andy's screen name:
Inland RV Center, In
-Rich-
09-19-2014, 06:30 PM
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs
, PA
short ribs
Here's what I found behind the skins!
09-19-2014, 06:38 PM
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
My '60 Tradewind Ribs end at various and sundry heights, except at the 1st and last "bow" ribs, which make it all the way to the bottom of the track . . . I think the "argument" in favor of justifying the willy-nilly rib lengths has something to do w/ the "monocoque" design.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
09-19-2014, 07:22 PM
1967 24' Tradewind
Alameda
I left a message for the guys at The VAP, and I have another source. Let's see what we find out.
~ Hurley
ingrid
09-19-2014, 07:25 PM
1967 24' Tradewind
Alameda
Surfpodthat looks like a second outer skin, maybe a replacement/repair job for that part? Look at my picture, there's another layer on mine too.
~ Hurley
ingrid
09-23-2014, 11:23 AM
1963 28' Ambassador
Northern VT
, Vermont
Normal, on the ones I've done, all pre '68, the front corner .032 channel type ribs are not connected to the floor. What has really shocked me is how few of the original extruded aluminum body bows [ribs] that are not connected to the C channel or floor. The worst example I've seen is my '62 ambassador. Only 2 full length bows connected to the floor, at the front and rear end caps. Every other rib stops at the top center and not attached to the floor, none full length and no apparent reason why not. Even the ones on either side of the entry door not anchored. I extended and anchored all.
09-23-2014, 12:02 PM
Corona
That is absolutely normal.
09-23-2014, 12:03 PM
Corona
Which Andy?
09-23-2014, 12:40 PM
Chelsea
, Michigan
I'm no structural engineer so I cannot give an expert opinion about any problems the "short ribs" might cause, but my intuition suggests this could be a problem. If it this occurred on my rebuild, I would make sure all the ribs extended and were secured to the C channel. It would not be a big deal to do this when the trailer is in a deconstructed condition.
Bob Martel
WBCCI# 5766
09-23-2014, 01:14 PM
1967 24' Tradewind
Alameda
That's what we were thinking. Most of the ribs are U channel so since w're getting ready to fab or buy some, we think we'll just extend what is there. He says it's easy and can't hurt not to.
~ Hurley
ingrid
09-23-2014, 01:17 PM
1967 24' Tradewind
Alameda
Then I start to worry about lengthening and connecting the ribs making things to stiff. I always find something to worry about.
~ Hurley
ingrid
09-23-2014, 01:21 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
The way the shell gets its strength, mostly from the outer skin, the short ribs will make little to no difference in rigidity...
I would not worry about them if it was my trailer.
