Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 06-05-2011, 01:58 PM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Drilling rivets
I found a countersunk bit that is much better -for me- in drilling out rivets
There in no ring left on the bit like a straight bit and it is easier to center
Darkspeed is offline   Reply With Quote
Old 06-05-2011, 03:04 PM   #2
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Looks good, but how do you keep it from enlarging the rivet hole?
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 06-05-2011, 04:34 PM   #3
Darkspeed's Avatar
1972 31' Sovereign
If I stop when the head spins off it does not enlarge it
Old 06-05-2011, 10:11 PM   #4
Ottawa , ON
Most folks find it much safer to remove rivets using either a #11 or #30 size drillbit (depending on the rivet size, of course). One of these days, you may find you have some extra-big holes in the skin.
You can centre the drill by giving the rivet a tap with a fine-tipped punch first.
But, it's your trailer, we're only giving you our thoughts.
'64 -Do I HAVE to drill out the buck rivets? robwok Belly Pans & Banana Wraps 4 06-14-2011 09:35 AM
78 argosy interior rivets argosyman General Interior Topics 2 05-17-2011 11:49 AM
Need help removing rivets. Breadbug Windows & Screens 16 01-19-2011 08:11 PM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 06:54 AM
