08-25-2011, 05:50 PM
1978 31' Sovereign
Oakley
What type of bath sink?
K, so I am rebuilding everything in the Argosy bath back to its original configuration with a few minor improvements. I am looking to replace the bathroom sink and counter with new, but don't have the originals (thanks to the PO). So was the original sink round, oval or square and what were its dimensions? Did the fixture mount on the bowl or basin? What material was it (plastic ABS, fiberglass, stainless, porcelain over steel or cast?
Lastly, if you were going to go new, what would you use?
08-25-2011, 06:06 PM
1972 29' Ambassador
grants pass
, Oregon
bathroom sink
I am also looking for the "right" sink.
I think the 13" stainless round is a good way to go,I am trying to find the best sink for the lowest price,
so far:
Kohler k2610-su bolero 13.5 at $138.54 is the nicest I have found,but something cheaper that isn't junk would be nice.
08-25-2011, 06:45 PM
Alamo Heights
The original in my '75 Argosy24 is rectangular overall, and one piece with the countertop in some sort of heavy fiberglass-feeling material. Here's a picture:
— David
08-25-2011, 07:14 PM
1974 31' Excella 500
Charleston
, South Carolina
asked and answered
I'm going to replace the sink in mine.
First, shallow sinks are an abomination. Sinks need to be deep.
Second, why not go for something that is multi purpose.. like a place to put wet stuff, wash stuff, etc?
This is something like what I've been considering.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
08-25-2011, 07:26 PM
Aluminum Falcon Mechanic
1972 31' Sovereign
Wesley chapel
Saw these at ikea , thought they looked very airstream...
08-25-2011, 07:28 PM
1978 31' Sovereign
Oakley
Yeah! And you can augment it's functionality by adding an old fashioned washing machine like this one...
http://www.columbuswashboard.com/
08-25-2011, 07:29 PM
1972 31' Sovereign
Wesley chapel
so far:
They have giant stainless steel half hemispherical salad bowls at ikea and I made a friend a sink out of one and it was like $30 in parts total
08-25-2011, 07:32 PM
1972 31' Sovereign
Wesley chapel
08-25-2011, 09:59 PM
1978 31' Sovereign
Oakley
I like that one for sure! Wonder if there is enough width in that tiny Argy countertop to properly center it? I'm getting on Ikea's site to check it out. Thanks Darkspeed.
08-25-2011, 10:24 PM
1972 31' Sovereign
Wesley chapel
Two more ideas for smaller.
The one in the background is a cool little sink.
08-25-2011, 10:32 PM
1999 25' Safari
On
, the road
Until you realize those ikea sinks weigh over 30 pounds.
08-26-2011, 12:16 AM
1978 31' Sovereign
Oakley
Yeah, that is exactly what I checked out. I've been looking at steel as apposed to china for that very reason. What ever happened to cheap stamped steel sinks and do-it-yourself formica?
I just received my final quote to refinish (paint) the tub, and they are all in the $450 range! For cryin' out loud, IT's PAINT! Not gold or some magical potion.
mad
08-26-2011, 07:48 AM
1999 25' Safari
On
, the road
Stamped steel and do-it-yourself formica is the route we are going to take. 4x8 sheet will be enough to cover the 3 counter tops we have throughout the trailer. For the bathroom sink I just may go the $4 Ikea serving bowl route and embed it 1/2 to 3/4 into the countertop with a little caulking around the edge.
08-26-2011, 01:16 PM
1972 27' Overlander
Granbury
I had a problem during re-hab of the bathroom in 72 Overlander. Floor had a soft spot so we disassembled the bath. Counters, tub, and sink are ABS and were yellowed. I sprayed them with Krylon or Rustoleum spray paint for plastic (can't remember which brand). Then just before reassembly, I knocked the one with the sink (7' wide!) off the workbench. Drain pipe was still attached to the sink, and it punched a hole in the sink. Yes, I said several choice words! I got a metal fabricator in town to duplicate all the pieces in metal. He even used tubing to form the raised lip that prevents drips over the edge. After he got done, I had the pieces powder-coated. It looks good, and is much sturdier, although heavier.
08-26-2011, 01:17 PM
1972 27' Overlander
Granbury
Oh, and I used a drop-in stainless steel bar sink I found on eBay. It's shaped like an Airstream. I gave the plumbing fixtures adn the sink to the fabricator, and he cut the holes in the steel.
08-26-2011, 01:54 PM
1950 Flying Cloud 7039
1950 21' Flying Cloud
Allen
Sinks are formed so that the drain is flush so all the water drains. What did you do to the salad bowl for a drain? I have seen others say they have done this same thing. I would like to also consider this if the drian works out.
08-26-2011, 05:01 PM
1972 31' Sovereign
Wesley chapel
I used a giant hardened impact socket and a hydraulic press to form a 1/8" recess. Cut the bottom hole with my vertical mill. Cut a small hole on the back top edge and installed a stainless bulkhead for an overflow drain tube.
08-26-2011, 05:52 PM
1978 31' Sovereign
Oakley
Darkspeed, I'm moving my Argosy project to your place. You have all the cool stuff!
08-26-2011, 09:19 PM
1972 31' Sovereign
Wesley chapel
I'm actually suffering, most of my good tools are still on pallets after the move from texas
08-26-2011, 09:49 PM
1958 22' Flying Cloud
Folsom
I was able to get a sink from a late model airstream from a rv boneyard. Picked up the sink and faucet for 25.00 cash. The cabinet was the hard part...
