Old 10-01-2015, 06:46 AM   #21
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Here is the almost finished product. I am still waiting for the tabletop to be laminated.
Name:	2015-09-18 17.04.58.jpg
ID:	249421   Click image for larger version
Name:	2015-09-18 17.05.12.jpg
bvcg1 is offline   Reply With Quote
Old 10-01-2015, 08:16 AM   #22
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Are you going to match the finish with the kitchen counter cabinets?
Are those cushions comfortable. Maybe just the angle but are they thick enough?
Nice job.
Kelvin
Old 10-01-2015, 05:06 PM   #23
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
The table top laminate will coordinate with the kitchen countertop. The kitchen counter has a grey/black/green simulated marble finish, and the table top laminate is a matte black with very faint grey striations. Since the table is the exact dimension as the seating cut-out, the first and last quarters of its length (connected with heavy duty piano hinges) will fold upon the middle two quarters, thereby allowing people to seat themselves more comfortably without having to scoot their butts around the table. When the two ends are laid back down in a horizontal position they will be supported by 4 heavy duty surface slide bolts.
The cushions are 3 inch thick very dense foam. I'm 265 lbs and I can't bottom them out.
Nice job.
Kelvin
Old 10-01-2015, 11:10 PM   #24
Obviously you have a better grasp of carpentry than I do. I can make a pattern easily enough, implementation of actual seating would be harder. Did you just break it down into boxes?
Libbitt is offline   Reply With Quote
Old 10-02-2015, 06:53 AM   #25
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Looks awesome Bruce. Who made your cushions?
Greg1410 is offline   Reply With Quote
Old 10-02-2015, 08:06 AM   #26
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
After a fashion, that's exactly what I did. I started by measuring the width of the back wall, allowing a few inches away from it for the front curvature. I cut a 2x2 for that length as the bottom plate, then went around each side from there. Once I completed that I measured out from those plates to create my inside sofa dimension and followed what I had just done, then went vertical. VERY IMPORTANT: all the assembly joints were used using a Kreg Pocket Hole Jig and Kreg screws. You will not get any kind of decent stability otherwise. Also, I used 2x2 Select pine. It cost me about $1.50 a foot, but worth the extra $30-$40.
Maybe these pics will help:
Name:	2015-08-23 17.05.35.jpg
ID:	249470   Click image for larger version
Name:	2015-08-24 16.45.54.jpg
Name:	2015-08-24 16.46.32.jpg
Old 10-02-2015, 09:26 PM   #27
Thanks!
Does this turn into a bed?
And... Do you know of the carpeting (mine is carpeted) goes under all the cabinets?
Old 10-03-2015, 07:30 AM   #28
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Yes it does turn into a bed. There are some pictures at the beginning of this thread that show the tabletop dropping into the seating.
I have no idea about the carpeting. his is my first Airstream
Thanks!
Old 10-05-2015, 11:21 AM   #29
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Looks Great
Impressed. Wonderful work.
tsunami is offline   Reply With Quote
Sofa cover for jack knife sofa k9jackie Sprinter and B-van Forum 0 05-28-2015 05:30 PM
Does anyone think the L shaped sofa is comfortable? Ntex Buyer Guidelines 16 11-27-2014 10:50 PM
wanted: tee shaped plastic beading CindyH General Interior Topics 3 05-02-2003 01:34 PM
Twinkie shaped Motorhomes Silvertwinkie General Motorhome Topics 12 03-06-2003 11:20 PM
Vintage Oval Shaped LP Tank Cover smily LP Gas, Piping, Tanks & Regulators 3 12-20-2002 04:52 PM
