Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 06-22-2007, 10:54 AM   #1
Profile:  1965 22' Safari
California , Kentucky
replace cabinet doors 1965 safari
Where Can I purchase 3/8 veneer plywood to replace a few damaged cabinet doors?
Most lumber yards stock 1/4 1/2 3/4
I suppose I could add veneer to 3/8 if it exists?
RiverRat is offline   Reply With Quote
Old 06-22-2007, 12:21 PM   #2
dnrtheil's Avatar
Profile:  1964 24' Tradewind
Portage , Michigan
Can not tell you where to get the 3/8" you are looking for. Here is what I just did. Two doors I removed the veneer and added new iron-on Red Oak veneer, door's were good except for the old veneer coming off. One other door I took 1/4" thick one-sided Red Oak plywood veneer, cut them just bigger than the existing door and glued the pieces together, good veneer sides out. Once dry cut the piece down to the size of the old door. Drill through the old door to mark hinge and knob locations for new door.
Later, Derek
dnrtheil is offline   Reply With Quote
Old 06-22-2007, 01:03 PM   #3
BoiseState
Spiffy Gem's Avatar
Profile:  1966 22' Safari
All my life in , Idaho
Images: 41
I've been building new cabinets, which includes 3/8 veneer ply. I've had to special order it from Franklin building Supply. Special orders cost much more . . .
I understand that most places can special order it, depending on the type of veneer you need. In my '66, the original was walnut, but since I have been building all cabinets from scratch, and am not a purist, I have gone with oak.
Locally to me, walnut is available through Boise , ID Woodcraft Store - Woodcraft.com .
Calvin
Spiffy Gem is offline   Reply With Quote
Old 06-22-2007, 01:14 PM   #4
Streamin 65's Avatar
Profile:  1965 26' Overlander
Marysville , Ohio
Images: 14
Door ideas
Your best bet is to contact a supplier to cabinet shops in your area and checking there. It's unlikely to find 3/8" at local lumberyards in a cabinet grade. The problem is most cabinet shops don't use much 3/8" ply, especially in mahogany or walnut, so it's not commonly stocked. However, you might get lucky and find some birch or oak in 3/8 (which can be veneered with a different specie if needed) It's out there, just not everywhere, and will take some time to locate. Veneer can be purchased at Woodcraft and online. If you don't have much woodworking experience, the folks at Woodcraft are very helpful.
As an option, you could use 1/2" ply and just rabbet the inside edges so the doors lay slightly (the extra 1/8") inside the cabinet. Just BE SURE to check if the rabbet will work with your hinges before making a bunch of doors. As an aside, today's 1/2" ply is more like 7/16" so you may be able to just use that. The ply doors in our AS are true 3/8", so you'd likely be looking at a 1/16" to 3/32" difference in thickness that may not be real noticeable.
I was lucky in being able to reuse most of the doors during our remodel except for the two long doors under the gaucho which were ruined. I just replaced those with with a couple solid walnut 1x10's I planed down to 3/8".
Good luck! --dave
Streamin 65 is offline   Reply With Quote
Bathroom cabinet doors handn 2004 Safari 3 12-12-2005 04:38 PM
Looking for ideas on a sofabed for my Safari Scotti General Interior Topics 0 09-03-2002 02:45 PM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 06:49 PM
Where do you suppose they put the antenna jack -73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 12:34 PM
What tires to replace with? Charcigar Tires 1 04-09-2002 02:08 PM
