Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 05-07-2013, 08:14 PM   #1
rbr
rbr's Avatar
2004 28' Safari
Semora , North Carolina
Need advice in mounting Corian
We found a fantastic deal on some salvage solid countertop at the local ReStore and I am replacing the original ply/formica. My question is... Should I remain with the original screw-only fastening, or should I add adhesive on top of the counter frame given the added weight and brittleness of the new material? Any experienced input is appreciated.
Bruce Robillard
Danville, Va.
rbr is offline   Reply With Quote
Old 05-07-2013, 08:19 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sounds great.. what's the thickness of the Corian? I would glue some wood strips to the underside with epoxy... scratch up the glue site with sandpaper to give extra grip, clean with acetone or denatured alcohol on fresh, clean cotton rag, then glue and clamp! Let it set overnight for a good bond... if this holds, you have a working solution! You can glue the wood in strategic places on the Corian, then side screw into existing counter uprights... this will allow flex in the cabinet, while giving strength... and allow for you to remove for 'service' in the area by removing screws..
Or you can just lay a bead of Liquid Nails on the cabinet edges and drop the Corian in place.. but results may vary..
Old 05-07-2013, 08:36 PM   #3
rbr
rbr's Avatar
2004 28' Safari
The Corian is 1cm., triple thickness at the edge w. a bullnose.
Bruce Robillard
Danville, Va.
Old 05-07-2013, 08:45 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Kewl find! I would go the route of gluing strips which would be near existing cabinet structure. Then side screw the wood surfaces to hold the tip in place. You can then remove screws iff you want to service inside that area.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-02-2013, 11:24 AM   #5
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
OK, stupid question: How do you cut the Corian to size? Special saw blade?
Old 06-02-2013, 12:25 PM   #6
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
If it was my trailer, I would use adhesive only. An adhesive silicone caulk would be my choice.
Alan
Old 06-02-2013, 12:26 PM   #7
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
You cut the stuff with a circular saw. Carbide tooth maybe a 60 or 72.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
Bigventure is offline   Reply With Quote
Old 06-02-2013, 12:28 PM   #8
A W Warn's Avatar
2000 25' Safari
Cut it with a router using straight edge or a guide. Sand and polish edges after cutting. You can saw it, but it takes more work afterward to finish the edges.
Alan
Old 06-02-2013, 01:13 PM   #9
1976 31' Sovereign
Oswego , Illinois
I agree with Alan use router as I have used much corian, but be aware it makes dust fine as talcum powder use simple mask & blow out router when finished, use strips to mount as suggested then screw into mounting points Bill
Old 06-02-2013, 01:41 PM   #10
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
The router is fine for curves with a guide and straight cuts as well with a guide. Use silicone calk to attach to a sheet of plywood. I put in Corian counter tops a few years back and and nothing has moved after a lot miles. If you need to join 2 pieces and need to hide the seam you can use the special filler that matches the color and then sand and polish. Try this link for supplies.
http://solidsurface.com/
Here are some pictures of the kitchen remodel on my 1976 31' Sovereign including the counter top.
Airstream counter top.pdf
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 06-02-2013, 05:41 PM   #11
drboyd's Avatar
1978 25' Tradewind
Dang! You welded up a whole new frame out of rectangular tube!! That's very cool!!
Old 06-03-2013, 07:32 AM   #12
adonh's Avatar
1976 31' Sovereign
Just wood strips
Don Hardman
1976 31' Sovereign
