08-15-2017, 01:29 PM
1972 29' Ambassador
Boynton Beach
Curvaceous Cabinets
After looking at an incomplete project for sooo long, I finally have my cabinetry act together. Just to make things fun, all cabinets are built as curves.
I laminated 1/8" okumne plywood to 1/8" lauan door skin, with 6 oz. epoxy cloth in the middle. All of this was wrapped around a custom form to get the curve. This method worked well, and once set, the curve didn't straighten out, like when using your basic yellow glue.
The upper section is carbon fiber and polished aluminum. The hood has a 12" automotive radiator fan in it, really sucks up the heat and odors. The hood was the only part of the project that I jobbed out, as my TIG welding skills are non-existent. Though I did make the patterns for the metal cuts.
The cabinet door under the sink tilts out from the bottom, and contains the trash. You can also see my over-and-under mount sink. I tossed out the funky old heater and installed a second AC under the new Dometic/SMEV range top. The floor-to-ceiling cabinet is closet above, and storage with a roll-out microwave below. Four LED puck lights make for nice task lighting at night, without having to turn on the overheads.
Still a little sanding, fitting and shelf work to do...
I've got pics of the process, if anyone is interested in more technical details.
08-15-2017, 01:38 PM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Those look really fantastic!
What is the object attached to the vent hood or is it just an optical illusion. It looks like there's something more there that you can't quite pick out in the picture.
Hittenstiehl
08-15-2017, 01:55 PM
1979 23' Safari
Wayland
, New York
Gorgeous!!!
08-15-2017, 02:14 PM
1955 22' Safari
Laredo
Sink
Over/under mount?
08-15-2017, 04:00 PM
1972 29' Ambassador
Boynton Beach
Thanks! That's a free-form carbon fiber speaker box/hood-attacher thingie! Maybe the attached pic tells a better story. It conforms to the curve of the inner skin, and flares out to hold the speaker. I built a wacky-looking form, then stretched black fabric over it. That got epoxied, then a few layers of matting and carbon fiber.
08-15-2017, 04:08 PM
1972 29' Ambassador
Boynton Beach
Originally Posted by BambiTex
Over/under mount?
Details in another post: http://www.airforums.com/forums/f38/...nk-152716.html
It's over the base plywood, but it's an under mount sink mounted under the laminate.
It's worked well, you can easily wipe off the countertop.
08-15-2017, 04:10 PM
2016 27' Flying Cloud
Manteca
Looks great!
I like the Star Trek motif upper cabinet electronics all over the place, and then you kept the Formica and aluminum trim below to maintain old school look.
Can you squeeze in a Keggerrater anywhere? Maybe under the sink and bring the tap out the top of the counter between the sink and stove?
Looks great, keep going man!
2016 27 Flying Cloud FB
2005 GMC Yukon XL 2500 4x4, Equal-i-zer Hitch, 4.10 axle ratio.
Tampa
That's beautiful!
08-15-2017, 04:20 PM
1972 31' Sovereign
Lexington
Beautiful!
Chris and Kay
08-15-2017, 05:33 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Very Nice!
Originally Posted by SuzyHomemakr
... That's a free-form carbon fiber speaker box/hood-attacher thingie!
That's exactly what it looked like.
Really like the curved cabinets. Nice job all around.
The hood is great, too.
Vaughan
08-15-2017, 06:29 PM
2011 25' FB Flying Cloud
Peculiar
, Missouri
Beautiful work!!! What are all of the gadgets in the cabinet above the sink? I love how you mounted the sink!
08-15-2017, 06:33 PM
2017 16' Sport
Suwanee
, GA
Wow that's awesome
08-15-2017, 06:35 PM
2017 16' Sport
Suwanee
, GA
I'll take a set
08-15-2017, 06:45 PM
2008 19' Bambi
Carlsbad
Fun stuff! A man needs his projects. Keep it free...
Russ
08-15-2017, 06:50 PM
1972 29' Ambassador
Boynton Beach
Originally Posted by 4riveteers
Looks great!
Alas, my keggerator stays on the patio. Though I do have a couple of Carbacap bottles ( http://www.austinhomebrew.com/Carbac...xoCT-8QAvD_BwE)to haul along some homebrew (and whenever I buy a commercial keg). Just as good!
08-16-2017, 07:22 PM
1960 33' Custom
Athens
, Georgia
Beautiful design and the execution looks exceptional.
I'm leaning towards a similar AC solution and wanted to ask how it works for you so far or if you had any learning points?
08-16-2017, 09:04 PM
1972 25' Tradewind
Grapevine
Lagunitas...nice! You have good taste in beer. Really great work on the laminations...I plan to do something similar on my rebuild.
08-16-2017, 09:11 PM
2019 27' Flying Cloud
Kansas City
, Missouri
That is freakin cool!
Piggy Bank
08-17-2017, 07:23 AM
1972 29' Ambassador
Boynton Beach
Thanks to all my fellow campers for the kind words!
I ran an entirely new cord and circuit, so that I plug into a 50A, then split it. The second AC is the only thing on the new circuit. The cord from the outside goes into a small household panel with a single 30A breaker, then to a single plug. Breathtaking in its simplicity!
As to how well it works, every little bit helps here in S. Florida. I also have a box fan that hangs over the bed to push the air around, and smaller fans here and there. I've got Reflectix in the windows and fancy NASA ceramic paint on the roof. Yesterday the temp inside was 81, with everything (28K of AC) going full blast. So not as cool as I'd like, but with a cold beer in my hand, bearable.
In retrospect, I wish that I'd re-done the insulation when I had everything stripped out. We were in too much of a hurry to go Airstreamin'!
08-17-2017, 07:42 AM
1972 29' Ambassador
Boynton Beach
It takes an amazing numbers of clamps, Harbor Freight is a good source for the cheap ones. I found that using 2X4s on the ends of the forms, and making the forms 1 1/2" thick worked well. You have to be sure that the forms don't torque around, otherwise the cabinet will set up twisted, never to lay flat! I used the store brand of epoxy from Glue Products Plus in W. Palm Beach, but another good brand is Basic No-Blush from Progressive Epoxy online. You want the good stuff that sets up clear, without the amine blush (white streaks) that can happen with stuff like West Systems (hey, at least it's expensive, too! )
I forgot to mention that I used Wood Kote Lite-N-Up Wood Bleach on the okumne plywood. It's easy to get an Airstream interior too dark, I think, and bleaching out the wood brings out lots of character. Five coats of Petit Captains marine varnish, and you're ready to install!
