Old 11-06-2011, 03:28 PM   #1
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
Bulk Head Moulding Woes
So we hit a snafu riveting in the bulkhead wall moulding back into our trailer. The rivet gun head from Vintage Trailer supply, and the pneumatic rivet gun from Harbor Freight both had too large of a head to seat the rivet snugly into the moulding since the metal ridge gets in the way. We went to Sears to try to get a narrower head and although better still would not let us completely seat the rivet in. We ended up making a wedge out of a piece of belly pan aluminum so that we could seat the riveter head over the rivet squarely. The wedge allowed an even distribution of pressure around the rivet head so that the rivets seated evenly. This is a bit hard to describe but we thought we would try since this may help others with replacing their bulkhead mouldings.
ID:	144686   Click image for larger version
ID:	144688   Click image for larger version
https://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
2vets is offline   Reply With Quote
Old 11-06-2011, 03:33 PM   #2
2vets's Avatar
1960 24' Tradewind
More photos. We bent the rivet slightly for better access.
ID:	144690   Click image for larger version
ID:	144692   Click image for larger version
Old 11-06-2011, 03:37 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Nice - looks like a great idea!
Chris
Old 11-06-2011, 05:43 PM   #4
Silver Mist
LI Pets's Avatar
Riverhead , New York
You can use 3/4" self tapping SS with loctite also
Old 11-06-2011, 05:53 PM   #5
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Looks good. I installed all the bulkheads in my 68 with the Harbor Freight gun. The heads on some rivets were not 100% flat but it was fast. Also, most of the rivets were inside the cabinets. The original rivets were not flat either.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-06-2011, 06:27 PM   #6
2vets's Avatar
1960 24' Tradewind
Thanks for the input everyone! Man, do we struggle over this trailer!
Head Units In Newer Models jeff4506 Audio, Video & TV 9 11-04-2011 03:02 PM
Movement at hitch head to shank Shayne50 Hitches, Couplers & Balls 9 10-24-2011 08:11 PM
Shower Head Height - 67' GT star kitty Sinks, Showers & Toilets 0 08-31-2011 12:35 PM
Transmission woes 1987_345 Classic Motorhomes 7 07-21-2011 09:43 AM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
