Old 11-27-2009, 07:21 PM   #1
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels , Wisconsin
Airstream Folding Table
Anyone have an Airstream folding table they want to sell?
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Ed Emerick is offline   Reply With Quote
Old 11-27-2009, 07:38 PM   #2
SteveH's Avatar
Common Sense , Texas
If you don't find one, maybe this will work for you: Oak Finish Folding Table with Remote Holder - Item - Camping World
Old 11-27-2009, 07:41 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Ed, Is there a specific year or style folding table you're looking for? You might try posting a add on Main Index - Airstream Trailer & Airstream Motorhome Classifieds. It's free.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-28-2009, 02:22 AM   #4
Silver Mist
LI Pets's Avatar
Riverhead , New York
I have the one from mine complete except for the rail that mounts to the wall. I'm sure you could buy that part new.
pm me
LI Pets is offline   Reply With Quote
Old 11-28-2009, 05:07 AM   #5
Images: 59
Would you like a set of chairs with that?
Old 11-28-2009, 07:36 AM   #6
RichHog's Avatar
1972 23' Safari
Houston , Texas
Folding Table
For which trailer are you looking to put it in? I don't know if all the folding tables in Airstreams were identical. Some are on the door side like mine and some of the curb side. I've currently taken mine out and apart to cut it down some as the size is a little big and heavy for the Tradewind. We've going to take about 6" off the width and then cover it with new formica that will match the counter tops. If you need photos to build one I can send. VTS has the table parts, leg etc. to make one.
RichHog is offline   Reply With Quote
Old 11-28-2009, 12:30 PM   #7
Moderator Emeritus
overlander64's Avatar
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings Ed!
I am guessing that you are probably looking for a drop-leaf style table for your recently acquired Flying Cloud. While not original Airstream tables, the following are sized somewhat comparably:
Timeless Elements Drop-Leaf Table
Heywood Wakefield Drop-Leaf Utility Table
1950s Vintage Pink Drop-Leaf Table
These aren't exactly the same, but my be somewhat in the same design realm.
Kevin
Kevin D. Allen
AIR #827
1964 Overlander International
Old 11-29-2009, 07:53 AM   #8
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
Photos?
Photos of what you are doing would be great! I am not much of a wood worker but I have said with this trailer I'm going to give it another shot! All I keep seeing is Doc Sevits my shop teacher in high school telling to move away from the table saw...........
This is for the 54 FC
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Old 11-29-2009, 08:06 AM   #9
RichHog's Avatar
1972 23' Safari
Houston , Texas
Table Top Surface
Will post some photos this week. Yes my wood shop teacher was similar, 8th grade, there was a 10" long wood splinter stuck in the ceiling above the table saw that he left there as a reminder for all of us to wear our safety goggles.
I've taken my table apart, about 8 screws and separated the metal frame from the wood. It's very heavy and difficult to set up. So that's where I plan to cut it down about 6" in width. When fully set up it's a little large for the space. I've bought formica for the surface that matches the new counter tops we put in. I've slowly reworked all of the old woodgrain plastic with wood veneers to this should finish up this phase of remodeling
Old 11-29-2009, 08:46 AM   #10
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Southern , Illinois
have table, will travel
I have taken the original folding table out of our '74 Ambassador. It's vinyl edge band needs to be replaced, and it may be too big for your Fying Cloud. Please let me know if you want me to post the dimensions and a picture.
Laird
maccamper is offline   Reply With Quote
Old 11-29-2009, 11:12 AM   #11
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Nfs fwi
Here are a few early sixties styles. Free standing folding type that stores away in the closet when not needed.
One is Uwe's...borrowed from another thread. My table has the plastic edging replaced with aluminium. and repainted.
ID:	91630   Click image for larger version
safari62 is offline   Reply With Quote
Old 11-29-2009, 04:38 PM   #12
2001 27' Safari
1995 36' Classic 36
Ambler , Pennsylvania
We ordered a wall mount from Colonial Airstream . worked great
nawwin is offline   Reply With Quote
Old 11-29-2009, 06:08 PM   #13
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
Yes Please
Laird
Please post, all help is welcome!
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Old 11-30-2009, 07:38 AM   #14
RichHog's Avatar
1972 23' Safari
Houston , Texas
Table Top Surface
I am in the process of buying 1" edgebanding for my table top, hopefully from Ace hardware, will let you know model and type if you need some, I may even wind up with a lot of extra as I was told I have to buy 6 12' sections.
Richard
Old 11-30-2009, 03:51 PM   #15
maccamper's Avatar
1974 29' Ambassador
Southern , Illinois
table pics
The table from the Ambassador measures 36" by 25". There are two table top pieces (only one is shown in the side view below, I took the second one off to make it easier to handle) so it folds out to a 36" by 50" surface. I used the two Soss hinges that connected the two table top pieces when I built the replacement table. Replacement hinges are a standard size and can be easily purchased.
There is a continuous piano hinge along the 36" side, which attached to a 1x2 wood batten which was attached to the trailer wall. All laminate surfaces are the imitation walnut as shown in the pictures. The table base slides out aways to support the second 25" wide leaf when it's folded out.
This table is available for the cost of shipping, or could be handed off at a rally or convenient meeting place.
Laird
ID:	91824   Click image for larger version
Name:	underneath table.JPG
Old 03-11-2010, 04:24 PM   #16
maccamper's Avatar
1974 29' Ambassador
Southern , Illinois
table parts
The old table pictured below just got too cumbersome to move around, so it's on it's way out. If some wants parts, please let me know. I have enclosed some pictures of the leg bracket per another request.
Laird
ID:	97933   Click image for larger version
Name:	table leg bracket 2.JPG
Name:	table laeg bracket 1.JPG
Old 03-12-2010, 06:20 AM   #17
RichHog's Avatar
1972 23' Safari
Houston , Texas
I'm cutting mine down to smaller size and put new formica on it.
Old 04-30-2010, 06:47 AM   #18
1973 29' Ambassador
Valdosta , Georgia
Table
Maccamper.
Do you still have the table?
I have a 1973 Ambassador that I'd thought I'd sold but after four years I have it back. Unfortunately the table is gone. Long story, but I'm in need of a table for it. The one that used to be in it was on the street side and it folded down plus you could slide it closer to the sofa
thanks
Gillguy is offline   Reply With Quote
Old 04-30-2010, 07:02 AM   #19
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I've got one. The finish is walnut with gray accents.
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
mello mike is offline   Reply With Quote
Old 04-30-2010, 07:32 AM   #20
maccamper's Avatar
1974 29' Ambassador
Southern , Illinois
I am sorry, Gillguy, I did not get any inquiries on the table, so the table tops went in the trash. I kept the aluminum frame for the recycle place, and it is still in the garage. You would have to make a new table top or find one somewhere.
On our Ambassador, all the laminate was fake walnut, and all the aluminum up front was copper anodized. I have taken out all the fake walnut inserts from the frame and edge trim. The table has no slides that allow it to move closer to the couch, that must have been something they did in '73.
The easiest thing might be to take up Mello Mike on his offer.
Laird
Need help with Excella folding table Nixon66 Cabinets, Counter Tops & Furnishings 10 08-31-2011 11:48 AM
aluminum folding table RevBec Airstream Lifestyle 12 09-28-2008 12:52 PM
Plans for Folding Table The Flintstones General Interior Topics 6 01-16-2007 07:23 PM
Installing folding table Happycampers General Interior Topics 5 03-13-2004 06:31 AM
