Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Caravelle > 1980 Caravelle
Old 06-02-2007, 05:19 PM   #1
Aluminumluvr
AluminumLuvr's Avatar
Profile:  1980 20' Caravelle
San Diego , California
Tambour Doors
Anyone out there found good replacements for these problematic doors? Thinking of buying a 1981 International and all upper and lower storage areas have these. I have a 1980 Caravelle and have problems opening the few I have. Any suggestions would be appreciated.
Thanks, Lyn
AluminumLuvr is offline   Reply With Quote
Old 06-02-2007, 06:50 PM   #2
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
The ones that open up and down have not been much of a problem; however, the ones that slide back and forth are a real pain. We replaced them in our 78 Argosy. Replaced the bathroom door with just a solid painted door. These are pictures of the kitchen doors made using the old tambour.
ID:	38470   Click image for larger version
juel is offline   Reply With Quote
Old 06-02-2007, 07:02 PM   #3
rmpray's Avatar
Profile:  1973 31' Sovereign
Bertram , Texas
Images: 21
juel,
Did you use the old tambour doors to build the new doors or just found a coplementary door? THey look good without changing the look. I've entertained the thought of converting my tambours to standard doors. As you said, no issue with the up down tambours, but the side rollers...grrr
Catmando
"There’s not much in life we can’t over-analyze”
rmpray is offline   Reply With Quote
Old 06-02-2007, 07:33 PM   #4
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
you should find a plethora of information if you do a forums search under "tambour"
The slickest and easiest idea I have seen is to make sliders out of flat aluminum sheets. With practically no work they will slide in the old tracks
Pay no attention to the man behind the curtain- WoZ
Lumatic is online now   Reply With Quote
Old 06-02-2007, 07:50 PM   #5
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough , winter home Zavalla TX
We have taken out the beds and gaucho out of our Argosy... I hate to throw away the tambour doors that were under the beds and gaucho.. we are not going to use them.. going , going ....
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30 (Costalotta)
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
Yamaha 3000
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 06-02-2007, 07:55 PM   #6
Lumatic's Avatar
Gone?
Me, Me, me
Marshall Hall
PO Box 1163/ 521 South 5th Street
Estancia, NM 87016
Old 06-02-2007, 08:09 PM   #7
Marshall... Do you need all 6?? Sent you a pm...
Marvin & Annie
WBCCI 10103
Yamaha 3000
Old 06-02-2007, 08:20 PM   #8
Lumatic's Avatar
You can never have too much tambour
I will take all I can get. Just to be clear currently I don't "need" any in the sense I have put all my tambours back together on both of my coaches for a total of 15, but I can always use spares for replacements.
If someone else is in more "need" than I, it's OK to send some or all to another Airstreamer.
Old 06-02-2007, 08:13 PM   #9
Lumatic's Avatar
gaucho stuff
Hey,
Scavenger that I am I can also use the aluminum framing from the gaucho if available. Especially the aluminum sliders with the plastic end pieces.
Thanks again,
Marshall
Old 06-03-2007, 09:23 AM   #10
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
We took the old tambour off completely and made new doors and put the old tambour on the door and framed it with molding. I love the look and now I have the storage space and I CAN ACTUALLY GET TO IT. By the way, be careful what you spray on those tambour doors. It can make them mushy and they fall apart. Don't ask how I know.
Old 08-09-2007, 11:40 PM   #11
Hippo's Avatar
Profile:  Currently Looking...
Battle Ground , Washington
Our 1975 we never had any .problems with the doors.
Hippo is offline   Reply With Quote
Replacing Tambour [Credenza] niftypkg Cabinets, Counter Tops & Furnishings 5 01-16-2007 01:36 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 04:12 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 09:34 AM
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 4 07-22-2002 02:00 PM
Must be sick of me by NOW - Tambour Door repair niftypkg Cabinets, Counter Tops & Furnishings 3 07-05-2002 12:11 PM
