Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-24-2014, 11:54 AM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
What size wiring for water heater?
Currently running wire for appliances/outlets in the Bambi II. I have dedicated circuits with 12/2 wire for the AC, microwave, and refrigerator.
Can I run 14/2 for the water heater? I am not even sure if I will have an electric water heater from the get-go but I want a line for it when/if I do.
Thanks!
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 06-24-2014, 04:02 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
They're 1400 watts which technically is within the 12 amp limit for 14 gauge wire. I ran 12 gauge wire for mine.
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
water heater size confirmation wannaroam Water Heaters, Filters & Pumps 2 06-13-2007 04:13 PM
How do I change water heater to different size? dickwhite1 Water Heaters, Filters & Pumps 0 06-21-2006 03:55 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
