Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 10-31-2016, 01:24 PM   #41
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Originally Posted by wingtipwalke View Post
@Losman, Did you buy the Pearl Rearvision system? They don't commit to the bluetooth/wifi connection working on an RV. Seems like an awesome solution if it works.
I spoke to these folks and on the surface this system looks like it might work till they told me that it was designed to only transmit a signal below 5 miles per hour. So that sort of became a deal breaker for me.
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 11-08-2016, 09:22 AM   #42
2000 31' Excella
Ontario , Canada
Originally Posted by Endodoc View Post
The 2017 specs state, "Rear View Camera Pre-wire" is standard. Does anyone know the specifics of this.
Jim.
I have a 2006 Classic with the same message. Has anybody discovered where to find this wire? Somewhere I have read that the connection is near the rear right stop/turn signals, but maybe they meant the top running light. I have had the covers off the stop/turn signal lights and could not see any extra connection.
woodytwo is offline   Reply With Quote
Old 11-08-2016, 12:52 PM   #43
Naples , Florida
Your 2006 does not have pre wire for a rear vision system. It only started with the 2017 models.
Lew Farber
lewster
Old 11-12-2016, 10:37 AM   #44
2000 31' Excella
Ontario , Canada
So does my 2006 have a pre-wire??????
Lew Farber
Thanks for the update. I guess that I just thought that when it said in my 2006 Classic 31 Owners manual "Your trailer has a 2-pin power connector pre-wired into the running light 12-volt system for the installation......... of a Back Up Camera." that Airstream really meant it. But I think in hindsight that they were just getting ready for the 2017 production year.
Woodytwo
Old 07-24-2020, 02:52 PM   #45
2010 27' FB Classic
N/A , Texas
I'm interested in purchasing a back up camera for the trailer now in 2020 and would like to see if anyone would like to update their posts on here since the thread is several years old. What brand of wireless system would you purchase now?
What method of tapping the power wire for the camera did you end up using? Lewster, where are the pix you said you were going to post with your method of tapping without extra drilling of holes?
Anybody go with the Furion wireless camera system?
Just want to know! Thanks.
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
Old 07-24-2020, 03:09 PM   #46
nryn's Avatar
2019 27' Globetrotter
Driftless Area , Wisconsin
I’m on my third voyager camera unit. Moisture issues with the first two, both of which were replaced under warranty.
If I were starting from scratch I’d probably try the Furrion. Voyager is fine for what it is but it’s nowhere near as good as, say, the backup camera in most cars at this point.
Airstream adventures and enhancements thread: Traveling with Tatay
Personal blog (photography, travel, woodworking, flyfishing, food): nryn.com
nryn is offline   Reply With Quote
Old 07-24-2020, 03:20 PM   #47
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
I have been pleased with the Haloview RD-10 recommended by GMFL - here is a link to my post about the install. Joe
What Did You Get For Your Trailer Today?
https://www.airforums.com/forums/sho....php?p=2377545
jayseejay is offline   Reply With Quote
Old 07-24-2020, 03:35 PM   #48
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
We have the Voyager which came with the 2019 Sport. It works okay (no water problems here on the wet coast). Range of view is a bit strange as it pointing to the ground so I can see the back of the trailer but not too far back to where I am going and not too far up even with level of the camera so I can back into a low roof edge or tree limb.
There is another thread which shows some interior installs that could work. Probably my gopro on the back window would be better than the Voyager!
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is offline   Reply With Quote
Old 07-24-2020, 07:15 PM   #49
FishByFly's Avatar
2017 25' Flying Cloud
Fayetteville , Arkansas
This spring, I drilled holes on my voyager camera as others have recommended. Gave the camera a few days in the sun to thoroughly dry out. I placed a sealant bead around the glass enclosure. Finally, I resealed the drilled holes and all other holes in the housing.
Drove this week in many rainstorms. All was good. No moisture visible.
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn
2023 F150 XLT
FishByFly is offline   Reply With Quote
Old 07-25-2020, 09:36 AM   #50
2010 27' FB Classic
N/A , Texas
PB_NB,
I noticed that on a utube review that the view was not great, I just figured it was not aimed correctly. Is the camera angle adjustable? I would not like to have it so I could only view the ground either. Being able to see tree limbs when backing would be one of the reasons for having a camera back there (IMO).
FishByFly, NRYN,
I was not aware of the water issue with the Voyager camera. I'll make sure to seal the camera prior to installation. I have not purchased the unit yet so this kind of info is helpful too. Thanks for the heads up! I may look at the Furion model a little closer too but I can't find much user info on it.
Old 07-25-2020, 09:59 AM   #51
2010 27' FB Classic
N/A , Texas
Thanks for the link. I guess you don't see any issues with the system you installed? That is a major plus and worth an extra looksee on my part. It looks more complicated to install than the other brands and that draw back could be a game changer for me.
Old 07-25-2020, 10:11 AM   #52
PB_NB's Avatar
2019 22' Sport
Bluto, have a look at this thread:
https://www.airforums.com/forums/f31...ra-194305.html
Jim installed an interior mounted camera which has some benefits. I think it is post #20
Peter.
Running Power to Voyager Rear-view camera garybair Audio, Video & TV 55 08-01-2018 06:54 PM
Voyager rear view camera image upside down jamieb1086 Audio, Video & TV 11 05-18-2018 05:32 PM
Voyager WiSight Camera works 50% of the time. Ted S. Electronics & Connectivity 14 08-20-2015 09:54 PM
Voyager wireless camera DeltaRon Electronics & Connectivity 6 06-16-2015 06:32 PM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 04:37 PM
