RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 04-10-2019, 03:35 PM   #1
2019 25' Flying Cloud
West Windsor , Vermont
Voyager rear view camera
The Voyager rear view camera has developed moisture in the unit. I can see the moisture beading up inside on the surface of the lens and LED’s. Have been in dry desert conditions for weeks and it hasn’t dried up on its own. Any suggestions on drying out or throwing out? Thanks
Peterf is offline   Reply With Quote
Old 04-11-2019, 04:31 PM   #2
dznf0g's Avatar
Oswego , Illinois
I had an off brand wireless camera system before Voyager was around. It fogged up after some time, so I decided it would be better to have it breathe. I drilled two very small holes, one on either side of the glass lense cover. Problem solved. Worked several years, until I replaced with the GM factory system so I could lose the separate screen in the cabin.
-Rich-
Old 05-18-2019, 03:44 PM   #3
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I have the same problem, it was supposed to be waterproof. Did you ever resolve this issue? I was thinking of calling them, but the warranty period is over. Not sure I want to spend the $ for a new one, hopefully the company will help me out when I call them. Did you try drilling holes in the camera, as was suggested by the previous post??
Hiho Silver is offline   Reply With Quote
Old 05-22-2019, 07:15 PM   #4
We did resolve the issue. We installed a new camera that now works fine. There was an additional problem related to the monitor and intermittent reception. Turned out to be a loose and disconnected antennae revealed when I opened up
the monitor. The manufacturer was terrific and sent a new one out right away no charge.
Peter Fleishman
West Windsor, Vermont 05089
Old 08-02-2019, 02:22 PM   #5
2019 26' Flying Cloud
Summerfield , Florida
Thumbs up Voyager Camera Warranty
Had the same. Started about 6 months into the warranty on that camera system. Called ASA Electronics (Distributor). Customer Service rep said moisture is a defect in the camera and asked to send photo same one as attached. Rep said that they will fully replace the camera plus pay for labor to install it. Found only Camping World nearby. Took some time for them to understand how ASA Electronics was going to pay for all 30 minutes labor. So. camera is now on order from ASA Electronics. Will update when repairs completed.
ID:	348320   Click image for larger version
Pubtym is offline   Reply With Quote
Old 08-30-2019, 10:28 PM   #6
ondaroadagin's Avatar
2016 27' International
San Anselmo , California
This is our third camera replacement for the same water infiltration problem! They said they wouldn't send us a replacement, it had to be replaced by an approved repair facility. We searched a thousand miles along our route, and every repair facility was booked 6 months into the future. They wanted me to send back our defective camera, and we informed them that removing the camera would leave an exposed hole open to the elements until a new camera arrived. Unacceptable! Finally they agreed to send it to an rv park to allow me to do the install. We'll see...Chinese build quality control...
Ars Gratia Artis
https://www.anamericanstream.com
Get our travel writing ebook on Amazon: "Wanderlust: A Scrapbook of life on the Road"
ondaroadagin is offline   Reply With Quote
Old 08-30-2019, 10:36 PM   #7
Our first camera lasted 3 years before water infiltration, the second lasted one month, now we're on our third. We'll keep you informed! We'd recommend asking company about this issue before order consideration!
Ars Gratia Artis
Old 08-30-2019, 10:51 PM   #8
2015 30' FB FC Bunk
Ayer , Massachusetts
I gave up on my Voyager camera early on. It’s blue screen most of the time. I plan to hardwire a new unit.
Ted S. is offline   Reply With Quote
Old 08-31-2019, 12:10 AM   #9
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Ted do you still have your voyager system?
GMFL is online now   Reply With Quote
Old 08-31-2019, 06:31 AM   #10
2015 30' FB FC Bunk
Yes, it’s still in place.
Old 08-31-2019, 06:44 AM   #11
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
My camera is the GM accessory unit that displays on my truck display; it lasted 1.5 years until Hurricane Florence penetrated it. I voided the warranty by opening it and was unable to fix it. So I purchased a replacement and installed it myself. You'd think these things would be waterproof, really waterproof. Not that hard to do.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-31-2019, 12:34 PM   #12
Thumbs up Sealing the Replacement Voyager Camera
Received replacement camera under warranty. Installed by JD Sanders Service Center. Good job. "Rich" new exactly how to do it. Said he has done a few. Enclosed pictures show he sealed screws and cable-wire grommets into the camera with clear silicone. Today, I took another look at it. The camera is assembled like a clam shell. Four small cross point screws holt it together. I checked the screw to make sure they were tight. I then coated both the top and bottom of the clam shell seams with silicone, the four small screws, the antennae entry point and finally the wire entry point grommet. We'll see.
ID:	350953   Click image for larger version
Old 08-31-2019, 02:12 PM   #13
2017 27' International
Lake Havasu City , Arizona
When installing, make sure there is a "drip loop" before the cable enters the camera's case. In other words, don't let the final inches of cable go downhill into the case. I lost two cameras to waterlogging before I learned this lesson, but none since.
Paprika is offline   Reply With Quote
Old 08-31-2019, 02:33 PM   #14
2019 22' Sport
Waynesville , Missouri
Yes. Same problem here. Disconnect camera from bracket, remove 4 screws in back. Take hair drier and blow dry totally. Reassemble. The leak is between the camera shell and the glass. No seal there, the water runs down the glass and into the camera shell. Get some silicone sealant, seal glass with A THIN bead. I also filled the area around the wire going into the camera. It didn’t look like any seal was there either. No problems since.
DAVSCH is offline   Reply With Quote
Old 09-08-2019, 10:55 AM   #15
Thumbs up Added Sealant
I took DAVCH recommendation and placed a small silicone bead along the glass connecting to the clamshell. Two days later I went through driving rain along central Florida during Dorian. My unit sat in pouring rain in Miami. No leaks or condensation.
Old 07-12-2020, 01:17 PM   #16
2021 25' Flying Cloud
Fredericktown , Ohio
Rear Camera Leak Repair
Ended up taking the rear camera apart. No rubber gasket on the glass. I have attached 3 pictures showing how the water got in. I used a clear silicone on the metal gasket that goes on the inside and also placed a bed of clear silicone on the outside against the glass and the metal. Lastly, I placed a bead of clear silicone where the cable goes into the back of the camera. I hope all of this works.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
MMCMRET is offline   Reply With Quote
Old 07-12-2020, 04:30 PM   #17
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
Try one of those little packs of Silica Gel that comes in your electronics, or if you have access to a diaper (unused preferably) you can take some of the pellets out and make pack (maybe with a tea bag type of material) that will absorb moisture then you can crack open the case and insert the pack. Leave it for some time to absorb the moisture in the case. Then remove it and try the silicon to seal it up. You want to get the moisture out of the air in the case so it doesn't fog up again.
PB_NB is offline   Reply With Quote
Old 07-21-2020, 03:40 PM   #18
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Do you have a photo of the camera with a proper "drip loop?"
Randy
Randy & Pat Godfrey
Florida Airstream Club (027)
WBAC# 1212 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
The best part of any trip is when you pull away from home.
SilverCabin is offline   Reply With Quote
Old 07-21-2020, 03:58 PM   #19
Mollysdad's Avatar
Agree.
It seems like a little thing, but any drops hitting the wire run downhill to the case. Have the wire go down, then up to the case.
Also, sealing everything will create another issue, condensation. As the temperature changes, water will condense out of the air and fog the interior.
We'd bag electrical connections at work, but always leave the bag open at the bottom. Obviously, on a moving vehicle it's hard, but even airplane windows have a pinhole on the inside bottom, otherwise the windows will get moisture inside.
Also, from the Voyager manual
ID:	373566   Click image for larger version
Name:	Screen Shot 2020-07-21 at 5.10.31 PM.png
Old 07-21-2020, 05:02 PM   #20
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Another option may be to install it inside so it peaks through the rear window. My camera is different and there is little degradation cause by the window. Downside is when the back window is covered by rain. Jim
Jim Flower is offline   Reply With Quote
Voyager Rear Camera Pairing abone Electronics & Connectivity 29 03-03-2021 09:12 AM
Running Power to Voyager Rear-view camera garybair Audio, Video & TV 55 08-01-2018 07:54 PM
Voyager rear view camera image upside down jamieb1086 Audio, Video & TV 11 05-18-2018 06:32 PM
Rear View Camera - Turn on Hazard and rear view flashes on and off. Tao Sprinter and B-van Forum 13 07-10-2015 06:01 PM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 05:37 PM
