Old 07-30-2005, 07:47 PM   #1
Univolt Fuses
I have a '67 Safari with what I presume to be the original univolt. It was fine this morning, but suddenly quit. I did find an internal fuse and replaced it. Everytime I power up (city power) the new fuse blows. Any ideas?
Keyholeren is offline   Reply With Quote
Old 07-31-2005, 05:57 PM   #2
If you have the original Univolt, I believe you only have two, 40 amp fuses on the battery leads. Please reply if you have more.
If this IS the case, it is possible that you have connected your battery backwards.
joatmon is offline   Reply With Quote
Old 07-31-2005, 06:07 PM   #3
Retired.
. , At Large
Rivet
I see three probabilities:
1- The battery is connected backwards, as was mentioned in the previous post. Check polarity and go from there.
2- You have a serious short in the low voltage system. Check your lights, fans, motors, etc, and repair as needed. Especially look at the wiring between the Univolt and the battery.
3- The Univolt is dead. Long live the Univolt.
Old 08-01-2005, 04:45 AM   #4
I do have a picture of the outside of the converter but I'm not sure how to add it to the thread. The opinion seems to be that there is a short on the 12v side some where. I'll start buy pulling the fuses as suggested to the various circuits.
Thanks.
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 10:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
