02-09-2016, 10:21 PM
Opelika
, Alabama
To go AC or DC on systems?
I'm looking at a water pressure regulator system http://www.xylemflowcontrol.com/beve...ter-system.htm
It comes in AC and DC. Any suggestions on which I should get? Since I would probably be using it at campgrounds, while plugged in and connected to their water line, I'm leaning to AC. But Amazon is full of people who've left positive reviews for the 12V version. Any suggestions?
02-10-2016, 05:29 AM
1978 31' Sovereign
Texas Airstream Harbor
, Zavalla, in the Deep East Texas Piney Woods on Lake Sam Rayburn
RV water pumps are almost 100% 12 volt.
There are many instances when you may need a water supply and not be connected to 110.
Go with the 12 volt - the size, cost, and reliability are built into the system.
Generally, volume tanks are not required on RV's. The pressure demand switches built into the pumps are adequate to provide sufficient flow and pressure to typical RV's.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
02-10-2016, 06:57 AM
Opelika
, Alabama
This application is a little different than a water pump. It's a pressure regulator mainly used to establish stable water pressure at a campground. Considering it would only be used while connected to city water or campground water, do you think the 110 volt would be better since it doesn't touch the battery?
02-10-2016, 07:04 AM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
That thing is going to take a huge space, and for it to work well I think it is going to require a rather large inlet or to be very close to the tank.
I installed a traditional RV pump that delivers 3 gpm, it does pretty well at delivering nice showers.
Brevi tempore!
02-10-2016, 07:12 AM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
It's a water pump with a pressure tank attached. Get it in 12V.
Lance
02-10-2016, 07:48 AM
1972 31' Sovereign
Benton
, Arkansas
Here is my take, if you want this for campground use, by all means buy the 120 volt version.
Revising my above comments, since this is going to be used in the campground, pulling from the pressurized water flow of the campground, my comments about the large supply lines do not apply.
Brevi tempore!
02-10-2016, 11:31 AM
Canyon Lake
An AC device pulling power off the batteries through an inverter will consume more of the batteries' power than and equivalent DC device that pulls power directly from the batteries. So if there are going to be at least some instances where you are using this while on battery power, I would go with the DC version.
02-10-2016, 11:35 AM
1996 34' Excella
Elberta
, Alabama
I may be dense, but in the years I've been using RV's from Class A to fold downs, a simple pressure regulator attached to the city water connection seems to do a very good job of pressure regulation, and they are not expensive...
For whatever it's worth
Larry
02-10-2016, 01:58 PM
Wise Elder
2010 30' Classic
South of the river
Why would you want one?
If the water pressure in the campground is low, can't you just fill the freshwater tank in your trailer as needed (from the campground water supply), and use that?
That said, either 12v or 120v would work. If you're using it as a portable unit outside the trailer, I guess I'd use 120v. If you're permanently mounting it, use whatever power supply is available at the location you've chosen.
