Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-17-2003, 08:28 PM   #1
gklott
gklott's Avatar
Profile:  2004 30' Classic
Johnson City , Texas
Images: 31
Stainless Steel Antenna Mount on AS Body
Am using a Shakespeare stainless steel marine antenna mount (4187-HD) for a ham radio antenna. Will mount it low on the street site.
The mount and all the hardware are marine stainless steel. there is a rubber gasket between the main mount part and the AS body.
Should I be concerned about SS in contact with the AS body? If so, how should I treat the installation to prevent dissimilar metals problems?
Anyone else with similar mount experience?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic dinette
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Old 11-17-2003, 08:35 PM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
You should not have any major problems with the dissimilar metals between stainless and aluminum. I would believe that the rubber gasket mount would be more than sufficent. We use stainless fasteners with aluminum all the time in architectural metals. Our biggest issue is the differing expansion/contraction coeficients. Which should not be a problem here.
Aaron
Old 11-18-2003, 12:00 AM   #3
Tinsel Loaf
Tinsel Loaf's Avatar
Profile:
Just keep it isolated from the AS body and you will eliminate any fruture headaches. Thats the easy thing to do.
Tinsel Loaf is offline   Reply With Quote
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 19 06-20-2004 05:11 PM
Weather Radios jcanavera Off Topic Forum 15 04-08-2003 10:47 PM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 11:01 PM
stainless steel wheel simulators Larry Brown General Motorhome Topics 11 11-26-2002 09:10 PM
test
