Old 09-30-2018, 01:15 PM   #21
Seattle , Washington
Whatever the cause, this kinda of thing is not to be messed with. Hot skin conditions have shocked and even killed campers. The problem is usually at a mis-wired or faulty-wired pedestal, not the trailer itself.
It's added work, but very simple to check a pedestal before plugging in with a multimeter or a similar device. Another item I use which is even simpler than a multimeter is a non-contact voltage tester such as the Fluke VoltAlert 1AC-A-II.
A great book for those intimidated by RV electrical systems is "RV Electrical Safety" by J. Michael Sokol.
Rollinstone is offline   Reply With Quote
Old 09-30-2018, 02:14 PM   #22
Donster's Avatar
1967 24' Tradewind
Bellevue , Washington
This happened to me last year when I had our 67 Tradewind hooked up to shore power at our barn built in 2005.
The smart people at this forum (I think it was Uncle Bob) said it was an open ground. I thought “no way we just built the barn.” But I got my tester (as pictured above by “Molly’s Dad”) and sure enough an open ground (the ground wire was disconnected). I carry that tester when we go camping because shore power is notoriously unreliable.
Donster is offline   Reply With Quote
Old 09-30-2018, 09:39 PM   #23
Tifton , Georgia
Are you near or under high voltage lines? The field put off by those high voltage overhead (or buried ) lines can light a neon bulb when you hold it. It can also shock you through the metal body of a vehicle or camper. Just a thought.
xyzabe is offline   Reply With Quote
Old 10-01-2018, 03:29 AM   #24
Delta , Pennsylvania
Originally Posted by Tbuck View Post
Last week camping I was experiencing low voltage shock while touching the camper outside while barefoot. While hooked to shore power turned off main breaker and still felt the shock. When I got home and access to multimeter I have 8 ohms between the ground pin and what I suspect to be neutral (upper right pin). So before I start getting into the breaker panel am I correct in stating they shoudn't be connected in any way. I never noticed this before but not sure if I was ever barefoot outside before. We've had are 27 FC for 14 mouths.
I've been through my AS top to bottom and haven't found any smoking gun. The ohms reading found earlier was a momentary reading on the refrigerator , inverter , AC unit circuits while parked in barn without power (would read continuity then quickly go to open circuit). After many hours on web and forum have determined camp site maintenance isn't always done by a qualified person, so there my have been a issue with the park power at my outlet box. I'll be testing all power sources from this point forward. We'll be going out camping later in Oct. and hope to confirm no electrical issue with our AS. I will repost with further development.
Tbuck is offline   Reply With Quote
Old 10-01-2018, 06:38 AM   #25
fastrob's Avatar
1976 25' Tradewind
. , Maine to Arizona
Got a indicator light at the back of my Trade Wind. If it glows when I plug 'er in that means the ground is bad.
Do not know if they stopped installing that feature.
If it glows I change the cord until the light goes out.
"Talk is cheap, Airstreams are expensive," Wally Byam.
25' Tradewind
'18 Promaster 1500 High Roof
fastrob is offline   Reply With Quote
Old 10-01-2018, 07:40 PM   #26
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I does NOT mean the ground is bad.
It means the hot leg and neutral are reversed.
The light is lit because it is wired between the neutral and ground.
Old 10-02-2018, 08:57 AM   #27
fastrob's Avatar
1976 25' Tradewind
Shocking!!!
Thanks for making that clear.
I know when the aluminum skin tingles the skin, time to check the ground.
25' Tradewind
Old 10-02-2018, 09:20 AM   #28
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
It usually does not mean check ground! It's a hot neutral swap!
Old 10-02-2018, 09:21 AM   #29
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
That light had nothing to do with ground!
It indicates a hot neutral swap!
Old 10-02-2018, 11:08 AM   #30
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The light will not illuminate if there is no ground.
It is not a ground fault indicator.
Old 10-02-2018, 01:40 PM   #31
2007 22' International CCD
Obtain and install an EMS/Surge suppressor. Don’t trust the so-called “reverse polarity light” to protect you!
HELP! Can I fix sagging Outriggers with shell on? Or just pull the shell? Mixter Repairing/Replacing Floor &/or Frame 3 01-24-2013 11:59 AM
To Shock or not to Shock jlovelady Shocks 35 11-16-2012 08:01 AM
Shell Shock :: 1967 Airstream Overlander till Airstream Registry Discussions 0 08-19-2011 08:30 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
