Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 10-07-2002, 08:19 PM   #1
74SovereignInt.
74SovereignInt.'s Avatar
Profile:
Rotary Light Switch
Ok, looking for another part. I need four rotary switches for my overhead lights. Radio Shack says " not one they can get, RV place says " uh uh", recommended an A/S dealer. I'm sure these have broken in the past so where have you found them. Thanks for your help.
74SovereignInt. is offline   Reply With Quote
Old 10-07-2002, 08:22 PM   #2
airstreamcaravel
airstreamcaravel's Avatar
Profile:
Light Switch help
From previous thread:
http://www.airforums.com/forum...t=light+switch
Hope this helps!
DMC
airstreamcaravel is offline   Reply With Quote
Old 10-07-2002, 09:48 PM   #3
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
If you have trouble finding the three way swiches, let me know.
Randy
Old 10-07-2002, 09:53 PM   #4
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:
Three way?
Hi, I'm replacing my three way "circle" overhead lights from my 75 Argosy TT. Two work for sure, one is sporatic in nature - it sometimes comes on, sometimes not. WD 40 may clean the contacts. Is this what you are looking for? They're available for a nominal charge. I'd post pictures, but the trailer is not at my house currently. I'll visit it soon this week though.
Marc
Old 10-07-2002, 10:10 PM   #5
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Overhead light rotary switches
Ace Fogdale Airstream in Iowa as well as Inland RV in CA. has them if they are the same as found on the '77 Sovereigns and Excellas. I believe that Brett (thenewkid) mentioned that they are available in Home Depot (or was it Lowes?).
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-07-2002, 10:18 PM   #6
3Ms75Argosy
Profile:
New switches
David,
I'm glad you found some sources. I'm replacing mine with some halogen 12V lights - I'll post when done. Good luck!
Marc
Old 10-08-2002, 01:37 AM   #7
DIMMER
Vagabond
DIMMER's Avatar
Profile:  1973 31' Sovereign
Semi, Pro Rock Crawler , Motorsports Photographer
I dont know about halogen 12V lights they might make to much heat, might get to hot!!!!!! just my 2cents.......
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
DIMMER is offline   Reply With Quote
Old 10-08-2002, 06:02 AM   #8
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Halogen replacement
Are you going to replace the whole fixture?
Probably way too hot for existing lens and probably to hot for skin.
My 4 cents.
Smily
smily is offline   Reply With Quote
Old 10-08-2002, 10:55 AM   #9
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Rotary Switches
FIX THEM, Take them apart, write down the wiring sequence., Clean them and replace. Easy to do.
Tom
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 10-08-2002, 11:10 AM   #10
3Ms75Argosy
Profile:
Halogen lights
Sorry I didn't make myself clear - I'm replacing the WHOLE light assembly with some IKEA lights, similar to what Uwe has done previously (search for 12v link). I'll post when I'm done. My test run with the lights went well - very little heat - and the lights will be spaced back from the skin with ventilation room. Thanks for the $.
Marc
Old 10-08-2002, 04:19 PM   #11
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Light switches
My 1971 has 3 ceiling light fixtures. It had the square light covers ( all 3 broken) and the rotary 3-wayplus off switches. The switches and lamp holders a re fine, but I could find neither the knobs for the tiny tread on the end of the switches, nor the correct fitting lenses. I removed the fixtures and installed 12V Halogen lights (NON) from Ikea. Nice light - cooler than the 4 bulbs were, and very very unobtrusive.
So if any one needs these fixtures, they're cluttering my toolbox right now........
Uwe
Old 10-09-2002, 10:11 AM   #12
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Local A/S dealer had the switches for 10 bucks each, and the parts person herself admitted (volunteered, actually) that they were a bit pricey for what they were. But you know..."factory part'. Anyway, I checked HD for something similar, and they had nothing, so I figured I'd just get the "unusual" switches from the dealer. 20 bucks isn't the end of the world....(needed 2).
A little while later, I was going through Lowe's, and just happened by a rack of assorted switches, and they had 3-position rotary switches that looked exactly like what I bought from AS....for 3 bucks. had the same number of wires, was the same size and shape, and the label said "off-on-on-on". might be worth checking out.
Chuck is online now   Reply With Quote
Old 10-09-2002, 11:06 AM   #13
uwe
418
uwe's Avatar
Images: 40
Hi Chuck,
What kind of switches were they? Got any pics?
I was searching high and low, because I wanted to use the original lights at first.I even bought the replacement lenses from InlandRV, but the shafts on all three of my switches were too short - could not mount the lenses. Andy was kind enough to take them back, because I could not make them work in my trailer. The switches work fine, but they are too short for the replacement lenses.
Uwe
Old 10-09-2002, 11:39 AM   #14
Chuck
Chuck's Avatar
Images: 99
Uwe, that's odd...why didn't you get switches to match from Andy? If my local dealer had them, surely he does too. I know, they're "highway robbery" prices, but hey... (no offense at all toward Andy; factory-parts=$$$$) we're still only talkin' a few bucks.
I don't have any pics handy, but I'll take some and post them. Andy's lenses look great, and I must say, in light of all the "dissing" there has been lately about $$$, these were a BARGAIN.
I wonder about AS's record keeping. My local dealer said that there were 2 kinds of switches in this era: long and short. Mine should be the "long ones". so I said, "ok, send me those". Well, what I got were quite a bit longer than what I originally had, and didn't have the same knobs on them. so I guess maybe I had the "short" one's. not worth worrying about..I just installed what they sent me, and they work; they just stick out lower than the original. (What I saw in lowe's looked exactly like what the dealer sent me). Another time, I asked the parts people there if they had tail-light replacements. They looked it up in their book, and presented me with what looked like the fixture for the "porch light" that is outside the front door. It has the same lense as the tail light, but the housing has a flange around it, through which the fixture is riveted to the skin of the trailer. With that flange, it will not fit in the tail-light housing. They double checked, and even called the factory, and confirmed that this was the correct light. It is not.
need light switch John Greenlee Electrical - Systems, Generators, Batteries & Solar 2 03-26-2004 10:27 PM
Interior Light Switch danesh General Interior Topics 3 12-08-2003 06:37 PM
Parts source for four position light switch overlander76 Electrical - Systems, Generators, Batteries & Solar 6 11-16-2003 08:24 PM
Light Switch JOECAR 1975-1976 Excella 500 1 03-16-2003 08:30 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
