Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-23-2004, 04:34 PM   #1
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
Pump Switch with new info
In my 1975 Tradewind 25' rear bath I have no power to the water pump. The pump works fine, I pulled it out and tested it. All fuses look good. The converter has been changed and my control panel has never operated correctly since the change. When I turn on a switch, light or pump, it shuts off the panel gauges. Have I lost the ground on the panel? Is this my problem? I spent that last hour searching old threads and think this could be it. If so how do I correct the problem?
I find that when I turn on the pump switch at the control panel, with the hot wire connected to the pump then touch the negative wire to the pump terminal the pump light on the control panel goes off. I continue to show no power on my test meter with the switch on or off.
Chaplain Kent
Chaplain Kent is offline   Reply With Quote
Old 06-28-2004, 08:39 AM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Sounds like a bad/missing ground. While I do not necessarily intend to sound flippant, you correct the problem by re-establishing your electrical pathways.
While someone who has had this problem may respond with an exact fix down to the offending wire's color, you will probably have to resolve this issue by checking all wiring connections with a multimeter. If you lack the time or patience, be forewarned that chasing bad wires can get expensive if you hire someone to do it.
Tom
water pump switch wheel interested Water Heaters, Filters & Pumps 1 12-11-2003 10:46 PM
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 05:35 PM
Time for a new demand H2O pump thenewkid64 Water Heaters, Filters & Pumps 14 09-26-2003 02:34 PM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 11:16 AM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 07:31 AM
test
