Microwave control panel failed NCVT test
I always check outside and inside with a non-contact voltage tester after powering up before either of us, or the dog, gets inside the Airstream. Everything is always fine EXCEPT for the control panel face on the convection microwave. Has anyone experienced this issue? Any advice on how to approach? I'm assuming I need to remove the microwave and then the front panel to see if any frayed or loose wiring, correct? Thanks for any input.
