Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 12-01-2019, 05:10 AM   #1
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
How the Victron Multiplus Works
If you’ve ever wondered how the Victron Multiplus hybrid inverters work, Victron has published this 20 minute video just for you. It’s helpful to have some basic knowledge of electronics. If you know what a sine wave, FET and a transformer is you’ll be fine.
It’s pretty clever how Victron combines an inverter and a converter in the same package that can also supplement your incoming AC with battery power.
daleyocum is offline   Reply With Quote
Old 12-01-2019, 05:45 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Yeah, that is one of the very big advantages of the package when running A/C on a small 2K generator. You set the control for the max amps you want to draw from the generator and the battery/inverter picks up any additional AC load that pops up.
Larry
lsbrodsky is offline   Reply With Quote
Old 12-12-2019, 06:49 PM   #3
1959 28' Ambassador
Victoria , Minnesota
Thanks for sharing!!! That was fascinating.
Kyacker is offline   Reply With Quote
Victron MultiPlus 3000 overheating SeaLevel Generators & Solar Power 28 03-30-2020 12:22 AM
Idle draw of Multiplus 2000 and Multiplus 3000 Dave-n-Janet Generators & Solar Power 10 11-24-2019 06:04 AM
Operation of victron multiplus inverter when below freezing fran&frank Batteries, Univolts, Converters & Inverters 34 11-11-2019 03:06 PM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
