Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-06-2009, 07:09 PM   #1
Canada , Manitoba
Help - Solid State Control Panel
I need to replace the 'Panel Display' switch on my Solid State Control Panel. My old one worked fine (and panel displayed good) until my wife pushed the switch too hard and broke it...
Can I solder any 12v switch as a replacement? What can I use as a replacement? Is this something that I can simply solder in?
As a temp solution, I was thinking on soldering 2 wires and simply touch the wire ends together (manual switch) to display the tank status. Can I do this or is it not recommended?
ID:	83515   Click image for larger version
SnoSheriff is offline   Reply With Quote
Old 07-06-2009, 09:23 PM   #2
ricknach's Avatar
1978 25' Tradewind
San Bernardino , California
Control Panel Switch
Take the switch out and try Radio Shack or any electronics parts place that is in your area. It may end up a different color but the switch will work.
Rick N
ricknach is offline   Reply With Quote
Old 07-06-2009, 09:34 PM   #3
darlingbooks's Avatar
2006 34' Classic S/O
Parkdale , Oregon
Images: 51
Is your broken switch a push on to read and then does it turn off when released? Or is it a push/click on and then another push/click to turn it off? If this is the type of stand alone switch that you have, a soldered on replacement switch should work for you, Just make sure that the replacement has strong enough electrical contacts to carry the load. If this is out of line, someone else should assist here s this was about to drop off the front page.
Steve
darlingbooks is offline   Reply With Quote
Old 07-07-2009, 08:52 AM   #4
Canada , Manitoba
My switch is:
  • push on to read and then release to turn off
I'll try Radio Shack for a replacement. I guess it's time to buy a soldering gun
Old 07-07-2009, 09:06 AM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I have found switches at NAPA when Radio Shack did not have what I needed. Other auto supply stores should have something depending on what's in your area. You should be able to find a replacement to avoid the "hold the wires together" technique.
You will never regret the soldering gun. Get heat-shrink tube too and you are in a new realm of electric repairs.
Vaughan
Old 07-20-2009, 06:55 PM   #6
Canada , Manitoba
I got 4 new switches at local Radio Shack for $8. The new one is already installed and all is good
control panel scottgaga General Repair Forum 2 06-18-2009 01:34 PM
Help- Control Panel went out all at once milesmason Electrical - Systems, Generators, Batteries & Solar 10 06-29-2006 08:56 PM
need help with control panel gord Electrical - Systems, Generators, Batteries & Solar 0 10-13-2004 06:46 PM
Control Panel RUSSELL Electrical - Systems, Generators, Batteries & Solar 4 08-04-2004 09:38 PM
GM a/c control panel rdm Mechanics Corner - Engines, Transmission & More... 5 11-11-2002 07:30 PM
