Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 12-31-2014, 07:57 AM   #1
SafariBez's Avatar
2014 30' International
Corsicana , Texas
Furnace motor squealing
I just turned on my furnace for the first time. It is functioning but it sure is making a loud noise on the outside. It is a high-pitched sound that I am pretty sure is abnormal and will disturb my neighbors. Any suggestions? Thanks.
SafariBez
SafariBez is offline   Reply With Quote
Old 12-31-2014, 08:05 AM   #2
Wayward's Avatar
Broadway , North Carolina
Two possibilities....
- bearing on fan motor - put a few drops of oil on it
-The fan blades are hitting the housing - if there is a set screw on the fan you can move it.
It may not be as loud to your neighbors as you think, you could run it a while and see if it gets worse or not. Then take it to dealer later.
If you do not want to run it anymore, your rooftop A/C may have a heat pump or heat strip to keep you warm.
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
Old 12-31-2014, 08:58 AM   #3
SafariBez's Avatar
Corsicana , Texas
Thanks Wayward. We are at home, trailer in the driveway. It is not a fan blade on the housing, but I guess it could be a bearing needing oil. Can I reach that with an oil spout without taking things apart? It has been running about 30 minutes with no change.
SafariBez
Old 12-31-2014, 09:11 AM   #4
1974 Argosy 20
Kooskia , Idaho
Since it is a 2014, and your first use, it would be covered by the 2 year warrantee and I would advise you take it to your dealer for service.
The bearings in the motor generally are very very hard to access, and are permanently lubed, that is no service is needed or provisions to oil them made. It has been my experience with two or three older units (yours is new) that if you take them all apart and do manage to lube them, they start making noise again very soon.
You could have a mud dauber nest inside which is being hit by the blower wheel and also could cause the noises.
Old 12-31-2014, 09:17 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
If it is the bearings and if they have failed already use the warranty.
I would mark the furnace before you take it in so you can check and tell if they replace the furnace or just attempt the short term solution of oiling the bearing, a not acceptable solution.
Small electric motors often have a washer at the end of the armature that acts as a trust bearing. That is the point that causes this high pitched noise. There are very hard to get to and even if simple oiling stopped the problem it would not be a permanent solution.
2004 Excursion 4x4
Old 12-31-2014, 09:17 AM   #6
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
http://www.gmcmi.com/wp-content/uplo...Dyna-Trail.pdf
Page 11 under burner adjustment. Improperly adjusted burner will cause a screeching or howling noise.
mayco is offline   Reply With Quote
Old 12-31-2014, 11:50 AM   #7
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Thanks for posting this - I'm going to check my own owner's manual for a similar adjustment. I replaced the fan motor already (it definitely was going bad), but the furnace has a high pitched whine with the new motor.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Wanted new or used furnace motor from Suburban NT30K gbryan1 Airstream Classifieds 1 01-31-2014 08:03 PM
Wheels loud squealing when NOT braking, help krohnjs Wheels, Hubs & Bearings 15 04-29-2012 12:53 PM
Airstream Classic 350 LE Motor Home 1992 Orig. Owner SAirstream Classic 350 LE Motor eBay Watch Airstreams on eBay 0 11-28-2010 10:00 PM
selling AO Smith 105 motor to replace original Armstrong blower motor eubank Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-07-2010 10:09 AM
alternator squealing john roeder Mechanics Corner - Engines, Transmission & More... 6 05-07-2009 06:46 AM
