In any event you most likely need at least new batteries. 6 years is pretty darn good life for them. Now, the converter/charger may have issues also, if it is flickering and making noise. It is working some, or the lights would not be operating at a brighter level at times, then dropping to a lower level. My guess is that it has become erratic in operation but can't guess if that is due to week batteries or not.
So, first new batteries, then if it still is happening, a new converter/charger is in order. If you do that, go the newer 3 stage charger route, a very worthwhile upgrade in any event.
Oh, if you have not done so, check the connections to your battery first, be sure they are clean and bright.
