Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 03-04-2014, 11:10 AM   #21
Mexray's Avatar
1978 28' Ambassador
Morada , California
Some thoughts...
1. I keep one of those cheap 'outlet testers' plugged into the galley's outlet to see if our AC power is correct any time we hook up to shore power...
2. Mexico uses 60hz everywhere we've been over the years - I thought 50hz was a European thing...??
3. The DC charging feature on most small inverter type generators is only rated at about 10 Amps - using this feature will take LOTS of running time if your batteries are depleted - I use the 1.5 'rule' for recharging - if your 80 Amp Hr battery is 1/2 depleted, you'll need to 'pump' 40 amp hours back into it for a full charge; using a 10 amp chg'r, 40/10=4 (hrs) x 1.5 = 6 hours on the charger...! You'll be much better off finding a higher rated AC powered charger for quicker recharges...
3.1...Charging from your 7-way tow vehicle's system isn't much faster that the above, due to the small wire sizes that limit available charging current..this works on the road when you have hours & hours of travel but not very good for trying to recharge when you're stationary just idling your vehicle...
4. We use those power strip protectors for all our major components plugged into Ac power inside our AS - TV, Sat receiver, DVD player into one...Microwave & phone chargers into another - while 'open ground' protection may be questionable, these devices do protect your stuff from voltage surges or spikes - I've seen them 'blow' at home when we have power outages restored with BIG power spikes...
5. It's true, electronic device prices seem much higher in Mexico - You'll probably be $'s ahead to just replace your microwave & converter/charger when you get back across the border - or - the converter might have an internal 'fuse' device that's blown and would cheaper to repair...
Hope you're having fun down there, otherwise...
Ray & Pat; Morada, CA
Old 03-04-2014, 01:07 PM   #22
daveswenson's Avatar
2012 28' International
Olympia , Washington
I have the Progressive Industries EMS-HW 30 C. This is much more than a surge protector. It monitors the incoming power as soon as you plug into the pedestal and will not allow current to flow if there are any faults with the power. High/Low voltage. High/Low current. Open Neutral. Open Ground. It also continuously monitors and will disconnect power at the first sign of trouble. Not cheap, but cheaper than a new AC or Microwave or Refer. Oh, and it's also a surge protector.
EMS-HW30C
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Batteries, Converters, and general dry camping help appreciated AirGal04 Full-Timing, Winter Living & Workamping 8 02-19-2014 03:52 PM
Coverter & DC Electrical Load Qs rwnash Batteries, Univolts, Converters & Inverters 8 09-28-2011 06:17 PM
Electrical blowout...HELP Chris N. Electrical - Systems, Generators, Batteries & Solar 8 09-15-2011 08:39 AM
Weird low voltage problem hhendrix Electrical - Systems, Generators, Batteries & Solar 6 09-01-2011 09:20 AM
Complete Rebuild of Electrical System worldinchaos Batteries, Univolts, Converters & Inverters 5 08-24-2011 09:16 AM
