Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-08-2016, 06:40 AM   #41
Box Elder (formerly Long Island, NY) , South Dakota
You might want to look into Sous Vide cooking. It uses 110VAC and is VERY versitile.
https://duckduckgo.com/?q=Sous+Vide&ia=web
NY24 is offline   Reply With Quote
Old 11-08-2016, 07:38 AM   #42
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
OR, precook your food, and reheat in the crock pot after you stop for the night.
Kay
Old 11-08-2016, 07:50 PM   #43
WaLee's Avatar
Nevada City , California
Great way to cook but not on the road!
WaLee is offline   Reply With Quote
Old 11-09-2016, 05:26 AM   #44
I heard about Sous Vide cooking from a full-time RVer who REGULARLY cooks that way while he's driving to his next location (he's a young engineer). He's made a set up that works well in his sink. Sets everything up in the AM and, when he reaches his destination hours later, his meal is ready. Quality zip lock bags work fine; food doesn't have to be under vacuum.
Old 11-09-2016, 09:44 AM   #45
dasams's Avatar
Palm Desert , California
Originally Posted by thiel View Post
I wanted to buy my wife a 12v crockpot, and it comes with a classic 12v round plug -- like would fit in a cigarette lighter in a car.
Buy one of these for $6.95 and attach it to one of your batteries. Then cook outside. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
If you want to cook inside, buy one of these for $11.95 and bring it in through the front door. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 11-09-2016, 12:03 PM   #46
WaLee's Avatar
I can see that working in a MH. Things get kinda rough back in the trailer underway. I haven't checked the draw my anova pulls. If its small and an inverter could work underway off the TV, and.. you can secure all that hot water in the sink without splashing out maybe it would work in a trailer.
Funny, my engineer son bought the Anova for us for Christmas. Makes the best Pork chops ever!
Old 11-09-2016, 03:49 PM   #47
Rich W's Avatar
I'm In , Kentucky
Originally Posted by TG Twinkie View Post
Richw46 has the inverter backwards. It provides 120 volts from a 12 VDC source of ample capacity.
Converters do the opposite.
I said the same thing twice, didn't I? As I get older, it just gets worse.
You would have to turn on the inverter, which converts 120 vac to 12 vdc. It should say 12 vdc and converts to 120 vac
D'oh!!!
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 11-09-2016, 04:02 PM   #48
Rich W's Avatar
I'm In , Kentucky
Originally Posted by Rob Cope View Post
I am a new owner of a FC25. What is a converter? And where to turn on? And why turn it on? I assume a converter converts something from 12V or from 120V. For example, if I want to operate a 120V space heater off the 120V socket, I hook into those other sockets, but how do they turn on? Thanks. Like the other chap, I feel kind of stupid about this matter.
Your AS has a converter and an inverter. The converter is powered by 120 vac shore power to provide the 12 vdc needed in the trailer and also charge the batteries.
The AS has an inverter to take 12 vdc from the batteries and make 120 vac for when you're not on shore power, to provide 120 vac for appliances, televisions, etc. that run on 120 vac. Usually, there are only a couple of 120 vac outlets, labeled as being from the inverter, in the AS because the inverter can run down your batteries in short order. The inverter itself requires 12 vdc even if nothing is plugged into the outlets.
You don't want to plug an an electric heater to an inverter outlet. Electric heaters use 1200 to 1500 watts and most AS provided inverters provide only 600 watts. You'll blow the fuses. Even if you didn't, your batteries will be dead very fast, that's a lot amperage to take from the batteries.
[Please let me have it right this time, TG Twinkie ]
-Rich
Rich & Yvonne
12v
Dumb,dumb, and dumber rebel beck Electrical - Systems, Generators, Batteries & Solar 18 06-11-2023 05:55 PM
12V Power Plug in for 12v T.V. Undertaker Electronics & Connectivity 12 09-10-2016 08:53 AM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
