Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-26-2013, 10:04 AM   #1
Tino
Tino643's Avatar
Blainville , Quebec
Dometic thermostat zone 1
Hello. I have a problem whit my thermostat. I can not see heat and the ac and furnace or not working. Zone 1 is flashing. Zone 1 for a 2013 is it the Ac or the furnace? Thanks
Tino643 is offline   Reply With Quote
Old 05-26-2013, 10:16 AM   #2
Naples , Florida
You should only have one zone visible, unless you have 2 roof units.
When the zone is flashing, it is telling you that it is ready to have the mode selected for that zone.
While Zone 1 is flashing, press the 'MODE' button and you should be able to toggle thru the available selections: FAN, COOL, HEAT PUMP, FURNACE....assuming that the roof unit has been properly installed.
If you have not received the manual for the thermostat, check with your dealer or Dometic.com Dometic
lewster
Old 05-26-2013, 10:22 AM   #3
Tino
Tino643's Avatar
Blainville , Quebec
Hello i have the zone 1 flashing and zone 4 not flashing! i have just 1 ac!
Old 05-26-2013, 10:43 AM   #4
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Suggest you go to the Dometic instruction manual for the thermostat, and look up instructions on how to do a reset.
That should take care of your issue.
2013 25 FC FB (Twin)
2013 Suburban 2500
https://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 05-26-2013, 10:56 AM   #5
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
If you don't have the manual, pm me and I will try and get you one tomorrow. If you have the manual, follow the instructions for a reset and program. Some of us have had to fiddle with the thing in the spring. It does not seem to like the winter. Almost human. Jim
Jim Flower is offline   Reply With Quote
Old 05-26-2013, 01:21 PM   #6
Naples , Florida
Turn off the thermostat at the on/off button. Then depress the 'MODE' and 'ZONE' buttons together until you see the word 'init' in the top window. This will re-set your thermostat and should solve your problem. you should then turn on the thermostat and try to set the zone 1 for whatever function you like.
If the problem persists and the thermostat does not respond normally, you either have dip switches on the relay control board inside the upper A/C unit that are not set properly or you have a communication error.
Let me know how the re-set goes.
lewster
Old 05-26-2013, 07:04 PM   #7
Tino
Tino643's Avatar
Blainville , Quebec
I had alrady do the reset and the same problem....
Old 05-26-2013, 07:06 PM   #8
Tino
Tino643's Avatar
Blainville , Quebec
The zone 1 is flashing and the zone 4 not flashing. 5 days before, everything was ok. But one day i see E1 and nothing work!
Old 05-26-2013, 07:30 PM   #9
Jim Flower's Avatar
1997 25' Safari
Tino, you should confirm that the phone cord on the back of the thermostat is attached properly. If it is, then check the other end that is located up in the AC unit. You can access this by removing 6 screws and then peek around with the help of a flash light. This end was loose on mine and once it was plugged in correctly, all worked fine. You have to follow the set up directions really carefully to get everything working again. Good luck.
Old 05-27-2013, 06:31 AM   #10
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
E1 indicates a loss of communication between the CCC (thermostat) and the control board in the ceiling unit.
Since this is a new trailer, it is quite possible that one end of the cable wasn't fully seated during installation and vibration allowed it to wiggle loose. If it doesn't prove to be something that simple, how far are you from a dealer who can address this under the warranty? Electronics seem to be very reliable, but there is an occasional case of infant mortality in new components and that is a reason for warranty.
If the system ever loses 12v power (battery switch is set to store and shore power is unplugged for example) the controller wakes up with a case of amnesia and the previously mentioned reset procedure cures all sorts of weird behavior.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 05-27-2013, 07:13 AM   #11
Naples , Florida
Just remember that this is a Dometic warranty issue (2 year Dometic warranty) and any factory authorized Dometic service center can look at your problem.....not just an Airstream dealer.
lewster
Old 05-28-2013, 07:47 PM   #12
Tino
Tino643's Avatar
Blainville , Quebec
Thanks for all the response. We went today at Us Aventure Rv of Davenport and hey tell me that is the chip in the Ac is defect. The order the chip and will replace tomorow.
Old 10-10-2015, 09:55 AM   #13
The Hen House
Mellen60's Avatar
2011 23' International
Grand Blanc , Michigan
Images: 11
Does anyone know what an E7 error message means? It was 31 degrees last night and I couldn't get the Dometic to work properly. When I first turned it in it ran great. Then as I got too warm, I turned the temp down 4 degrees. Then it wouldn't come back on. I'm ready to rip it off the wall. Help please!
www.ThePaintedPost.com
Life and Times on Kupiec Farms
Mellen60 is offline   Reply With Quote
Old 10-10-2015, 10:16 AM   #14
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
E-7 is loss of 120v power.
Landrum is offline   Reply With Quote
Old 10-10-2015, 11:23 AM   #15
Naples , Florida
It's not your t/ stat, but the 120 VAC power feeding the upper unit. Check your circuit breaker or main power supply. The t/stat operates on 12 VDC.
You lost 120 VAC at some point during the night.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
Old 10-10-2015, 03:19 PM   #16
daveswenson's Avatar
2012 28' International
Olympia , Washington
Were you trying to use the furnace or the heat pump? You don't need AC power for the furnace, and 31 is too cold for the heat pump to operate efficiently.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 10-10-2015, 04:35 PM   #17
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
It happened to me this summer.... your batteries are toast!
glcmranger is offline   Reply With Quote
Old 10-13-2015, 03:40 PM   #18
The Hen House
Mellen60's Avatar
Images: 11
E7 Loss of Power
Thanks for the help. I ended up calling the Dometic help tech line and for $32 of support, the fix was, "Just unplug it, wait 5 minutes, and plug it back in." It worked after that. Ugh!
Thank you for trying to help me. I appreciate it. Kelly
