Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-16-2014, 03:30 PM   #1
mizzadventur's Avatar
1998 25' Safari
Alexandria , Virginia
Checking / Resetting Circuit Breaker
I've tripped a circuit (ran the microwave and the space heater at the same time) this morning. I've found the circuit box behind the sofa. And I have some spare fuses (30A) although I am not sure they are the right ones. I can't figure out how to reset the circuit, or if needed, replace it. I have a 1998 Safari.
I searched the forum for previous threads on this but they must be buried, as I couldn't find any related discussions.
ID:	209794   Click image for larger version
mizzadventur is offline   Reply With Quote
Old 04-16-2014, 03:35 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
There are no circuit breakers in your fuse box. It's a separate breaker box, probably within a couple of feet from where the shore power cable cable comes in through the skin.
Old 04-16-2014, 03:37 PM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
What you found are the 12V fuses. There's also a 120v breaker panel somewhere in the trailer.
— David
Old 04-16-2014, 06:32 PM   #4
1998 25' Safari
Oh. Ok. That makes more sense. Now I need to find that box. Many thanks!
Resetting 12 volt circuit Cathy&Pete Electrical - Systems, Generators, Batteries & Solar 7 10-20-2010 11:15 PM
Resetting circuit breaker? 68Glbtrotter Electrical - Systems, Generators, Batteries & Solar 4 11-02-2005 06:19 AM
circuit breaker pops ... eubank Electrical - Systems, Generators, Batteries & Solar 3 01-30-2004 11:37 AM
Circuit Breaker Happycampers Electrical - Systems, Generators, Batteries & Solar 4 07-26-2003 06:51 PM
New circuit breaker strip FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 10:25 PM
