Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-02-2014, 04:24 PM   #21
1978 31' Sovereign
Mukwonago , Wisconsin
78 Soveriegn control panel issue:
My panel works perfectly but intermittently. Disassembled, checked continuity at all connections and solder joints. Fuse good, power on etc. Broken feed wire?
lhkrueger is offline   Reply With Quote
Old 08-10-2020, 12:11 PM   #22
1969 27' Overlander
Castlegar , British Columbia
Originally Posted by bakes View Post
I'm having a similar issue once i installed a new water pump, I have checked and rechecked every fuse, I am lost. All my electronics are working except for the control panel, and really the only thing I need from it is the water pump.
bakes, this sounds similar to the issue I am having with my 1969 OVerlander, did you ever figure out what was going on?
Purslane is offline   Reply With Quote
control panel, electrical problems
NEW: 5th Wheel Airstream Airtrekker Boondocking 43 05-30-2020 09:11 AM
Build your own Control Panel DanielB 1973-1974 Excella 500 0 03-21-2011 05:59 PM
How to repair the control panel? DougZ General Repair Forum 1 01-10-2011 05:52 PM
