Old 08-03-2020, 05:13 AM   #1
2017 19' International
Tallahassee , Florida
Checking voltage in trailer
How would one check the voltage coming into the trailer?
I've grown concerned that busy campgrounds, especially on a warm afternoon, may have demand so strong that the system can't deliver the full voltage load.
WhereStream is offline   Reply With Quote
Old 08-03-2020, 05:25 AM   #2
2018 25' International
Slidell , Louisiana
A surge protector with low and high voltage detector and a digital readout is a good investment ($180-300) and then you can easily know power quality and trailer current usage. Otherwise get a medium quality (true rms voltage) multimeter ($25-35 another good investment) use the probes on any wall outlet and read trailer voltage from there.
Brian
Old 08-03-2020, 05:27 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Many of us have an EMS that plugs into the pedestal, then our cord plugs into the EMS. The EMS reads out voltage and in most cases protects against severe undervoltage. Without that, you can simply measure the voltage with a voltmeter plugged into one of your outlets..that is close enough.
You are right, quite a few campgrounds do not provide full voltage, especially when every trailer in the park has A/C running.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-03-2020, 05:27 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
My KISS solution...
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 08-03-2020, 09:44 AM   #5
Trilla the Traveling Tube
kpfate's Avatar
2018 22' Sport
CHEYENNE , WY
Larry
Ditto - this was one of our first purchases before we took our new AS out for her first trip! My husband carried an electrical license for many years and is a stickler for proper protection. We even have a surge protector system on our house.
As Fate would have it
2018 GMC Sierra 1500
2018 22FB Sport
kpfate is offline   Reply With Quote
Old 08-03-2020, 09:50 AM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
First off: If you don't already have a multimeter, get one. Even the $20 version from the big box store will do ok. Then learn how to safely use it to check various voltages / currents / circuits in the trailer and TV. You *will* need one of these and the ability to use it at some point in time.....
Second: Indeed, get a proper EMS unit for the trailer. I happen to like the Progressive units. There are others out there. To some degree it's a "you get what you pay for" sort of thing. The setup I have allows me to check voltages and currents without getting out of my chair in the trailer ....
Yes, this is a bit of money. It's money well spent when you see some of the odd things campgrounds try to do to your electrical feed.
Old 08-03-2020, 10:08 AM   #7
2019 23' Flying Cloud
Waterford , New York
Autoformer
I second the autoformer.
I own a small Marina where my airstream spends most of the summer. On Friday afternoon when when most of the customers show up to their boats, turn on ac, water heater And pop dinner in the oven the voltage dips for a while. The ac on my airstream sounded like it was laboring. Added the autoformer and end of problem. The boat systems seam to be a little more tolerant than the AC on the airstream.
Larry1492 is offline   Reply With Quote
Old 08-03-2020, 10:14 AM   #8
2020 30 Globetrotter
Phoenix , Arizona
This is a little overkill but this is what I have in addition to a 50 amp surge protector with a interior bluetooth monitor.
https://www.airforums.com/forums/sho...66#post2392166
Rootbeer2014 is offline   Reply With Quote
Old 08-03-2020, 10:16 AM   #9
Johnny North's Avatar
2019 27' International
Martensville , Saskatchewan
I also use the Progressive Industries EMS. Yesterday, with a full campground on a very hot day, the PI EMS protected my a/c unit and other electrical components by shutting down power to the rig on low voltage. (below 104 volts) E4 error code on EMS and E7 error code on AS panel.
The Progressive Industries EMS unit would be the first essential purchase I would recommend before hitting the road.
Mark
Johnny North is offline   Reply With Quote
Old 08-03-2020, 10:35 AM   #10
2019 25' International
Washington , Washington, D.C.
Wherestream - this is what I use. Know what's going on at a glance.
https://www.amazon.com/Prime-Product...6472505&sr=8-2
PatLee is offline   Reply With Quote
Old 08-03-2020, 10:36 AM   #11
2003 19' Bambi
Blue Mountains , Ontario
Cheap solution
Killawatt plugs into a socket and displays constantly. I also used to plug into 30 amp adapter, plug your standard 110 circuit tester into it and then plug into campground pedestal. I could then tell the amps at the pedestal and whether the 30 receptacle on the Post was properly wired. I have upgraded for constant monitoring but still leave the killawatt plugged in inside the AS to monitor real-time the volts.
https://www.homedepot.com/p/Kill-A-W...4400/202196386
Craigleith is offline   Reply With Quote
Old 08-03-2020, 10:43 AM   #12
Photo of what my polarity meter it shows when plugged in:
Old 08-03-2020, 11:04 AM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I have a old analog volt meter from Radio Shack that I keep plugged into a bathroom outlet.
Old 08-03-2020, 02:08 PM   #14
2019 30' Flying Cloud
Homosassa , Florida
I have a 50 amp Airstream so I use Hughes Power Watchdog that manages voltages and will shut off power if a low or high voltage situation. It has Bluetooth so I can check on my phone.Click image for larger version
Tater is offline   Reply With Quote
Old 08-03-2020, 03:11 PM   #15
aftermath's Avatar
Spokane , Washington
This is what I do. KISS is how I roll.
aftermath is offline   Reply With Quote
Old 08-04-2020, 10:56 AM   #16
2020 27' Flying Cloud
Howell , MI
This is what we are using with our Airstream as well. I really like it; very robust contactor and separate user-replaceable circuit board with the surge/spike protection components. I bought a spare board when I bought the unit. The Bluetooth capability is a really nice bonus. Nothing against Progressive Industries EMS units; we have one in our bus conversion and it has served us well. PI was sold, and there warranty is not what it used to be (which was lifetime, no questions asked). Still, I would not hesitate to use one. Two of the most important things we don't leave home without are the TPTMS and the EMS.
BandLAir is offline   Reply With Quote
Old 08-06-2020, 12:36 PM   #17
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
One low voltage problem another camper and I solved at a large campground was realizing we were too far from the power transformers in the park. There were several. We were having low voltage because we were at the tail end of the electrical distibution system. We move closer to a transformer and got much higher voltage.
guskmg
Old 08-06-2020, 01:23 PM   #18
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Like Craigleith I keep a Kilawatt plugged in.
2019 Ford Expedition Platinum
Old 08-10-2020, 05:55 AM   #19
RidingmyRV's Avatar
2015 28' International
Portsmouth , Virginia
Very nice!!!! Thanks
RidingmyRV is offline   Reply With Quote
CZone Trailer Battery Voltage spotted_dog 2016 - Current Classic (all lengths) 13 10-12-2019 11:01 AM
Bambi 19'CCD goes in production 7/29, I'm checking my list! Rhodie Our Community 11 07-28-2004 07:21 PM
Checking water in the battery... drboyd Electrical - Systems, Generators, Batteries & Solar 1 08-15-2003 09:37 PM
Checking in time 53flyingcloud Our Community 7 04-02-2003 01:14 PM
Checking the Anode Rod... ALANSD Water Heaters, Filters & Pumps 1 05-08-2002 08:23 AM
