Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-04-2015, 12:51 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
93 Entrance Door Grab Handle/ doorbell
My doorbell does not work. The problem is corrosion of the doorbell wire located in the entrance grab handle which also houses the deadbolt lock. There is not enough wire to be able to work on it. It looks like I might have to take off the handle to access the wires. Anybody have any advice?
Old 07-04-2015, 01:24 PM   #2
1974 Argosy 20
Kooskia , Idaho
I am not sure if this is advice, but I owned an Airstream 310 motorhome with a working doorbell for about 10 years. No one even once used it, and I expect that about 99% of my visitors were not even aware that that little black button was a doorbell, or felt the need to use it.
Old 07-04-2015, 02:45 PM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
I actually never envisioned a doorbell until I got this Excella a few months ago. I did think of hooking it up to an outdoor Aaoogah horn under the door, but you are probably right unless there was a big sign with arrows it would not get used.
The fix may be more trouble than it is worth.
Anybody else out there ever use your doorbell?
Old 07-04-2015, 02:56 PM   #4
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I repaired the doorbell on my 89 325LE. The wiring follows the channel down to the floor and exits through a hole near the entrance step. My doorbell which I replaced is located on the drivers side wall behind the couch.
bobmiller1 is offline   Reply With Quote
Old 07-04-2015, 03:38 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
[QUOTE=Lumatic;1646768Ihe fix may be more trouble than it is worth.[/QUOTE]
I guess I have to do something, because right now I have a live wire in my handle.
Old 07-05-2015, 12:00 AM   #6
1974 Argosy 20
Kooskia , Idaho
My 310 had the power go to the doorbell chime itself first where it was fused, then on to the button for control. Disconnect the wires at the doorbell chime itself.
Got the door grab handle off-yippi perryg114 Doors & Locks 6 08-02-2016 08:39 AM
Grab Bar entrance door adonh Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 08-08-2013 09:12 PM
Grab handle goshawks00 Doors & Locks 7 03-22-2012 02:16 AM
Grab Handle KATYBELLE Our Community 1 10-06-2010 09:51 PM
Cast Emblem and Grab Handle pitting (removal?) PA BAMBI II Clearcoat, Exterior Paint & Trim 6 05-14-2010 04:39 PM
