Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-22-2019, 12:27 PM   #1
2019 25' International
Providence , Senior Electrical Engineer
Question 50 amp plug prong protection
Does anyone have any suggestion besides plug the cord back into itself on how to transport and protect the power cords prongs for the times that it "drops" to the ground while your trying to coil it up for transport?
I have cable carrier straps:
https://www.amazon.com/Camco-Easily-...gateway&sr=8-3
but I am finding that I've seen the cord prongs hit the ground a few times and nothing worse than trying to bend a prong back due to carelessness on my part.
When I got my 15' might cord, it had a molded plastic piece that goes over the prongs.....I'm looking for something like that.........that can't get lost during camp time. I haven't seen any plug boxes that make sense.
So anyone have a tip on how to handle it? Or a product that does just that?
EDIT:
I just found this:
https://www.amazon.com/Prong-Shield-.../dp/B072KQQFL6
I am wondering if they make this in a 50 amp version???
kittmaster is offline   Reply With Quote
Old 05-22-2019, 12:49 PM   #2
Mollysdad's Avatar
No, I've never seen a 50 amp cover.
You won't be able to plug the two ends together because they're not compatible.
I too had the plastic part, I wonder where it went?
You could buy an adapter for 50 amp to 30 amp and leave it on the plug. It's probably less expensive than a 50 amp plug and may actually come in handy (although hanging a 50 amp cable from a 30 amp adaptor is destined to fail)
Old 05-22-2019, 12:55 PM   #3
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
we replaced it with a smartplug
they make them in 30A and 50 A
such more robust construction
waninae39 is offline   Reply With Quote
Help please! Melted prong on 30 amp plug KenSanLan Electrical - Systems, Generators, Batteries & Solar 15 04-17-2016 07:38 PM
3 prong rocker switch/hot water heater? Lothlorian Electrical - Systems, Generators, Batteries & Solar 5 03-13-2012 09:50 PM
Bargman #99 Tailight refit 6-prong to 7-prong silverkeeper 1960 - 1965 Safari 6 03-05-2011 10:01 AM
Original 2 prong cord, how do I make it safe? Jabba Electrical - Systems, Generators, Batteries & Solar 21 07-12-2010 02:01 PM
3-prong plug converter to fit in regular outlet codybear Off Topic Forum 13 08-21-2006 09:00 PM
