11-20-2009, 08:34 AM
1975 25' Tradewind
Summerland
, British Columbia
Hello new project
Hi I'm new here although I've been watching the forums now and then for a little while. at any rate we have taken the plunge and now have a new project. 1975 25' airstream. It has been parked for many years on the west coast in the forest but under cover. I will have to tow it back home in December (snow storms + mountains) and I'm anticipating replacing the tires and going through the lights before we leave.. just wondering what else could give us a problem. Are the wheel bearings difficult to quickly re-pack? Anyway here is a picture... the shell is straight with only a minor dent on the bottom front. Any information would be appreciated. it looks like I need to load my photos to flickr or something like that to post?
Cheers
11-20-2009, 08:41 AM
2002 25' Safari
Dewey
Welcome to the forums.
A 25' 1975 Airstream is an excellent choice, but I might be a little bias.
Instructions on posting pictures from your computer are located in this thread:
http://www.airforums.com/forums/f138...ics-44928.html
Richard
11-20-2009, 08:50 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Welcome to the Forums. We're glad to have you with us.
If you are going more than a couple of miles, new tires are a must. Also, if you will be traveling at highway speeds, trailer brakes are essential. There is a good chance that the trailer brakes may not be operation after the trailer has set up for a number of years. You will also need a trailer brake controller for your tow vehicle.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
11-20-2009, 12:16 PM
1975 Argosy 24
Malakoff
Leave a day or two early to allow for unexpected preparations
that may be necessary before towing it home. Go slow and be
carefull!
11-20-2009, 12:32 PM
1993 34' Excella
Estancia
Originally Posted by moosetags
If you are going more than a couple of miles, new tires are a must. Also, if you will be traveling at highway speeds, trailer brakes are essential. .
Brian
Not sure if I personally would use adjectives like "must" and "essential". I would agree with "desireable" and gives you a greater margin of error safety factor. It's your choice, but others (including myself) have towed trailers which have not been moved for years with minimal preparation.
Along that line is the liability factor. You wreck do to the trailer not being roadworthy and it's on you.
How long is the tow?
You can tow just about anything if you go slow and easy. I would be more concerned with having brakes on a Sovereign than a Tradewind, more concerned with big downhills than flat, and more concerned with a dinky tow vehicle. I bring along grease for the bearings if I get an overheating bearing, a spare wheel, tow lights (so I don't have to mess with the trailer lights) , a jack, and tools.
11-20-2009, 12:39 PM
1967 22' Safari
1960 Caravel
Edmonds
Wheel bearing are not tough, just messy.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
11-20-2009, 01:29 PM
Wheel bearings are easy. The hardest part to me is removing the wheel, so if your putting on new rubber anyway you're halfway there. If the unit has been sitting around for years I would definitely go through the bearings, brakes and tires before taking on any mountains or winter weather. Just my personal take on towing.
Congratulations on your new Tow.
Regards,
Kevin
William C. Swinney
11-20-2009, 01:45 PM
1975 Argosy 24
Malakoff
There may not be a usable spare either. You will want to know
so that you can get a wheel also.....flat tires are no fun...even
worse with NO SPARE!!! If I had to do what you are about to do,
I would have a pickup bed full of assorted tools and stuff.
I suggest the 5 P's
Prior
Planning
Prevents
Poor
Performance
11-20-2009, 04:27 PM
Ottawa
, ON
Congratulations on your new investment, and welcome to airforums.com!
You answered "City:" with "yes", by the way. The intent was for you to put a city name in there, so unless you live in a town called "Yes"...
IMHO, on a 34-year-olf trailer, I would most definitely re-do the brakes. But not by putting on a bunch of little new parst, rather, by replacing the entire backplate, which will give you new connections, shoes, springs, magnets, and everything. They're probably all bad, and this will be the cheapest and fastest way to safety. The drums should still be OK, but would most likely benefit from some sanding to remove any rust.
While you do this, take the bearings off (two per wheel, or 4 per axle, if your '75 is like my '74) and re-pack them as per the videos. Wear rubber gloves, unless you fancy washing hands for a day or two to get the black out.
Don't be tempted to fill up the water tank, since if something goes wrong in the plumbing, it will most assuredly fail when you least want it to: on the road!
Hope you have safe trip home, and above all POST PHOTOS of your new rig ASAP, puhLeeze?
ps: Flickr or Photobucket are easier to live with and just as easy to use as the forum's built-in image handler.
11-21-2009, 10:47 PM
1975 25' Tradewind
Summerland
, British Columbia
Wow amazing response here! thanks for the info and suggestions to everyone. Our trip will involve one ferry ride and about 7 hours driving. I hour through Vancouver BC 4 hours of mountains.
11-21-2009, 11:02 PM
1975 25' Tradewind
Summerland
, British Columbia
11-22-2009, 09:42 AM
1971 21' Globetrotter
Arvada
With your routing you will diffenitly need operational brakes.
12-04-2009, 08:04 AM
1975 25' Tradewind
Summerland
, British Columbia
Just a quick question I'm trying to figure out if I can just pull the four wheels off my car hauler and put them on the airstream for the trip home. Would anyone know the bolt spacing for wheels on a 1975 25' Airstream trailer? 5x?
12-04-2009, 08:26 AM
1975 Argosy 24
Malakoff
Sight unseen - I would say "NO". Bolt pattern and
wheel offset being different could result in problems.
Suggestion - Take a hydrolic jack and the stuff
needed to take the wheels off...take all 4 wheels
to the nearest tire shop and put new ST or LT tires
under it. You will have to remove the wheels to
repack the bearings anyway. New tires and repacking
bearings are worth about 4 to 6 hours....then you need
trailer lights too. Go straight down the middle on this stuff
and things should go well for you.
12-11-2009, 04:29 PM
1975 25' Tradewind
Summerland
, British Columbia
made it home
Well it is now parked in the driveway. I managed to get all the lights and brakes working befor leaving. However the brake system decided to give out after an hour of driving. As condition were really good we went carefully and had an uneventful trip. I'm really impressed with the Tacoma pulling the airstream. Turning a 180 inside the ferry, 9% hills, snow covered mountain roads etc. No question a great truck.
Now comes the project... we were going to gut it completely but the interior is much better than expected. just one door missing and the front seating area. So now the pondering begins.
12-11-2009, 07:16 PM
Ottawa
, ON
Well, depending on where in AB you are, from the weather you may have had so far, there will be lots of "pondering" time!
Congrats on getting it home!
Please buy new backer plates (loaded with all the bits), you will need the brakes at some point in your towing experiences to come...
12-12-2009, 07:26 AM
1975 25' Tradewind
Summerland
, British Columbia
Guess I better update that... we now live in Penticton. I wouldn't have considered driving it back to Alberta. Now I only have 3 months for winter projects
And yes have four complete brake units on order.
12-12-2009, 10:33 AM
1970 27' Overlander
ARLINGTON
, TEXAS
SilverL- Thanks for this.. You Tube. I would have never thought to check you tube for this information. Cynthia
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
12-12-2009, 11:43 AM
Ottawa
, ON
Well, I have one cousin in Kimberley, and another in Revelstoke. I'm trying to work out a plan to get out and see them next summer.
As Stephen Wright says, "Small world but I wouldn't want to paint it."
Good move on the backers.
12-13-2009, 04:49 PM
1969 31' Sovereign
Goodyear
Hi! I am a proud new owner of a 1969 Sovereign (in need of lots of repairs) and the trip bringing it home was - well, let's just say it could have been better. The advice above is great and I would definitely follow it. Our trailer also had lots of missing/broken interior hardware, loose doors, etc. We used "blue tape" (painters masking tape that doesn't leave marks) to help keep the interior doors from flopping around when we towed it. We took it off right when we got home and it left no marks on the woodwork. Just test it to make sure it won't leave marks on whatever you stick it to. Good luck!
"Whether you believe you can do a thing or not, you are right." -Henry Ford
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
'61 project
truckasaurus |
1960 - 1964 Overlander |
8 |
03-02-2008 02:18 PM |
We have a 'project'
BogieGolf |
Member Introductions |
14 |
09-26-2007 12:05 PM |
A new project
crispyboy |
12 |
03-28-2007 03:45 PM |
My next project
azflycaster |
Awnings |
23 |
01-20-2006 08:47 AM |
New Project
Janets Husband |
General Interior Topics |
28 |
04-21-2005 08:45 AM |
