Originally Posted by kleimanr
My airconditioner makes noise that can only be heard outside. My dealer says it is normal. If you have a newer 30' SO Classic I would appreciate if you would let me know if your rooftop unit also makes noise. Thank you. Richard
mr. kleimanr,
If you could be a little more descriptive, I/we could possibly help you out.
*Does this noise happen when set to the air conditioner function or also on heat pump?
*Does it happen with just the fan running and the compressor off (fan only setting)
*Can you try to put the noise into words....whirring, clanking, rubbing, etc.
I've installed a few new Penguins and the squirrel cage fans were rubbing on their shrouds creating a noise that was audible only from the outside. On a new trailer, that should be a warranty fix! Penguins carry a 2 year labor and 3 year parts warranty.
Let us know what you find...........
