Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 07-02-2011, 06:58 PM   #1
1966 26' Overlander
St Louis , Missouri
need air conditioner
HI,
I don't currently have an air conditioner. I am wondering where the best place to install on my '66. And what type to get?
ally is offline   Reply With Quote
Old 07-02-2011, 07:12 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings ally!
Welcome to the Forums and the world of Vintage Airstream ownership!
Originally Posted by ally View Post
HI,
Unlike more recent RVs, air conditioners do not install into an existing roof vent opening on our Vintage Airstreams. A hole must be cut a set measurement from the number one (front bow) - - the hole is centered fro side-to-side on the roof and the opening is braced with rot resistant wood or aluminum extrusions. Once the opening is cut, you will find the power cable coiled up very close to the hole, and may also find the end to the condesate drain as well (I am not certain if the condesate drain was standard or not in 1966). Bill Thomas RV is probably your closest Airstream dealer, and his service department should be able to advise you on the proper placement of the air conditioner on your coach.
Good luck with your coach!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 07-02-2011, 09:54 PM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
Another important point is that you want to get an AC unit that's intended for an Airstream-type installation, so it'll have the right pan to deal with the condensate drain and the shape of the roof. That's hearsay gathered from obsessive reading of the Forums, though, I haven't had to swap one out yet.
— David
Air conditioner went south... Bing-Bing Furnaces, Heaters, Fireplaces & Air Conditioning 12 06-16-2011 06:14 PM
Old air conditioner removed... Steps for new installation Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-14-2011 03:25 AM
Air conditioner shroud repair for 1974 Sovereign Tom Lafferty Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
Air horns on 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-25-2011 07:49 AM
Air conditioner wattage ubuckster Furnaces, Heaters, Fireplaces & Air Conditioning 12 02-25-2011 12:53 PM
