06-30-2014, 03:59 PM
1969 27' Overlander
Sudbury
, Ontario
'69 Overlander Full Floor Replacement
Hi Everyone,
I've just purchased my first Airstream. Its a project to say the least but one that I'm certainly excited to tackle. I've brought it home and cleaned it up but want to do things right as we plan on keeping it for as long as possible.
First step is to take over where the previous owner left off and redo the floor. I'm working through all the posts and am also hoping for some insight (or warnings) from your experiences as I paint the frame and replace all of the floor. I read the posts about using gantries and should have listened. Lets just say I went through a little "separation anxiety"...at least everything is still wrinkle free.
Here's a few pictures so far.
06-30-2014, 10:18 PM
Yellamo
1965 26' Overlander
Windsor
Wow! Very impressive....I have started pulling my belly pan rivets and will soon see the frame and who knows what else, on my '65 Overlander...It needs a complete overhaul...semi straight and stock interior. I do plan on posting pics... I will follow your progress and hopefully be more motivated! Thanks Bryan O.
07-01-2014, 07:16 AM
1978 31' Sovereign
Texas Airstream Harbor
, Zavalla, in the Deep East Texas Piney Woods on Lake Sam Rayburn
Looks great! Please continue to post pics, time, and costs - if you are comfortable.
Your experience and thread will be a great tool for those attempting the same thing in the future.
Luck.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
07-01-2014, 03:22 PM
1969 27' Overlander
Sudbury
, Ontario
Frame doesn't look as bad as I expected. Far from perfect but I've seen car builders do more with less. Belly pan off throughout the rest of the week and I'll start cleanup on the weekend.
07-01-2014, 06:25 PM
1966 17' Caravel
Newport
, North Carolina
I think that I have seen this floor shot before so was it to that point when you got it? You are doing great and look like you have a plan so did you get the interior parts? Best advice is take your time and when you get frustrated take a break! Please keep us posted because you are motivated!
Welcome
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
07-01-2014, 06:30 PM
1966 17' Caravel
Newport
, North Carolina
I see now I found your first thread and did not associate with you! You have made much progress and yes I will read whatever thread you post on! Looks great
Cliff
Yes I said that! Or did I?
07-01-2014, 06:38 PM
1969 27' Overlander
Sudbury
, Ontario
Thanks RM66caravel. Look forward to any insight you can offer.
07-03-2014, 08:50 PM
1969 27' Overlander
Sudbury
, Ontario
So....where should I be posting the full story of my rebuild? This is turning out to be an interesting story. The frame is in awesome condition. Most of the guys on my street are converging in my driveway to "bench race" about layout ideas. My one neighbour has basically told me to go f%ck myself because I've brought this "eye sore" to the street and yelled to his wife that I'm a "head case". Ya...
Just don't know if this is the right place to post my full adventure. This story is about to get funny.
07-04-2014, 05:30 AM
Hendersonville, NC
, North Carolina
Drabnormal, why don't you use the blog feature of the forum for adding your adventure? It's under More>Member Blogs.
Pat
07-04-2014, 05:47 AM
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru
, New York
Originally Posted by Drabnormal
Hi Everyone,
It looks like you've got a pretty good handle on what is involved in a "body off" floor replacement, however the only thing I'll caution you on is the precarious position of the body. Take some time & lower it to the ground & tie it down somehow. These bare bodies have a tendency to "fly away", destroying your dream.
Colin
07-04-2014, 04:09 PM
1969 27' Overlander
Sudbury
, Ontario
Thanks Kokopat and Colin. I have dropped it down and hooked straps to the interior ribs with the other end tied to concrete filled cinder blocks, the 8x8's it's sitting on, and a picnic table...I am a bit paranoid now though. Kokopat, I will start a blog shortly.
I do have a frame related issue before I start that. It seems the worst place on the frame is centred around the step. Is there anyone making replacement weld on parts for that area? I'm hoping for the piece of channel at the top. If I do have to make my own, can someone send me pictures of theirs? Here is what I have now.
I have no idea what holds the step up while travelling.
Thanks.
07-04-2014, 09:25 PM
1967 24' Tradewind
Alameda
Congratulations!!
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
07-04-2014, 10:48 PM
1969 23' Safari
Blenheim
, Ontario
Above the step, what looks like a pull handle is in fact a pull handle. On the other side of the handle there is a tab that fits into the slot on the step. Its that tab that holds the step up while travelling. If you need a pic I can post one in the am.
07-05-2014, 06:45 AM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Right here
You are in the right spot. Keep posting pics and documenting your progress as above. This keeps it all in one thread that is easy to follow.
I recommend you sandblast the frame. Then you'll be able to fix any areas that have rusted through. The step areas you have pictures of are pretty common. Cut out the rust perforation, shape/form and weld in new metal.
Good luck and keep up the good work!
Lance
07-05-2014, 10:27 AM
1969 23' Safari
Blenheim
, Ontario
Sry not much light under there.
07-05-2014, 10:29 AM
1969 23' Safari
Blenheim
, Ontario
I guess pics would help.
07-06-2014, 06:52 PM
1969 27' Overlander
Sudbury
, Ontario
Attachment 215859Attachment 215860
Frame is almost ready to go out for sandblasting. Thanks for the pics Cyquest. The pull on mine is pretty messed but I'll see what I can do once I get the frame back.
07-06-2014, 07:05 PM
1969 27' Overlander
Sudbury
, Ontario
Learning this rebuilding thing as I go. Family by my side the whole way.
1969 27' Overlander
2011 Ford F150 Ecoboost
Twitter - @mikep95
Instagram - mikep951
07-13-2014, 06:51 PM
1969 27' Overlander
Sudbury
, Ontario
I fits in the garage!
http://i1303.photobucket.com/albums/...ps1zifxypx.jpg
I should be able to pick up my steel tomorrow. I prepped all the spots I'll be welding today (in the shade) and should have it out for sandblasting by the end of the week. There's three shops that are able to do large projects so hopefully one of them can get it back to me quickly. I'm anxious to get the plywood down and shell back on. As always, I have my trusty helper by my side.
http://i1303.photobucket.com/albums/...pscs2jvxjv.jpg
1969 27' Overlander
Twitter - @mikep95
07-15-2014, 10:52 AM
1969 27' Overlander
Sudbury
, Ontario
Hi All,
Things are coming together rather quickly. I'll save the pun for when the body goes back on.
The frame is out for full sandblasting and urethane coating.
New wheel wells are being made up as I type
3/4" Marine plywood is in transit.
I'm hoping to have all the pieces together by the 25th so I can do another marathon session and have the body back on by August 4th. I read on a thread here somewhere (but cant find it) about using thin rubber gasket material between the aluminum and steel to help prevent any reaction between the metals. Can someone point me to the thread or a source for it?
Also, every second frame rail is 3/4" lower. I was planning on first putting a sheet across the lower but spanning all the way to each of the higher rails. Then I would lay my second sheet across and screw it all together. It would essentially give me a 1.5" floor. I don' know if this is overkill or not.
