Old 02-20-2012, 01:08 PM   #29
salzburg , salzburg
Today was window day, so I decided to put the Lexan in the front corner windows to start with, quite an interesting thing to do to try and get all the frames on, screws in, whilst bending the lexan into the correct shape, i then cleaned the excess sealant off with acetone!!! what a mistake to make!! the acetone took the shine off the window and made it go cloudy so I had to start again, I got the second bit in and am now waiting for another order of Lexan luckily I found it cheap on Ebay. in the meantime I put my rear window to the glazers to get glazed and my Baufol insulation arrived so next oppurtunity will be sealing the lap lines and installing the insulation.
whoops!
Had to bring it upstairs as the sealant won't set under +5 degrees
can't wait to get that and the windows in and run a heater!
on another note:
I want to put an order into Air Spruce as i would like a piece of Alclad to patch a few bits and pieces but i don't want to just order that so was wondering if anyone knew the size of the rivets that go in the belly pan so i can order them at the same time,
many thanks.
mrgreen is offline   Reply With Quote
Old 02-20-2012, 01:49 PM   #30
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Originally Posted by mrgreen View Post
... so was wondering if anyone knew the size of the rivets that go in the belly pan so i can order them at the same time, ...
#11 drill, so that would be a 3/16" pop rivet. You need to get the style with the "large flange," and I don't think Aircraft Spruce has them. I order them from Vintage Trailer Supply.
Zep
MindsEyePhoto AirstreamDoctor PygmyKayaker
- Corporations are not people
- If you want the public to have an opinion, start the Draft within 60 days of hostilities
- If you are betting other peoples' money, you get a regular salary
Zeppelinium is online now   Reply With Quote
Old 03-01-2012, 04:45 AM   #31
salzburg , salzburg
so progress is slowly moving forward although my welder is dragging his feet somewhat got both of my front corner windows glazed and the flat back one should be ready to puick-up tommorrow, I removed all the tape residue from around the windows which was a hell of a job having been on there for so long but i managed to find some 3m glue remover from the jobsite which i'm on at the moment which was probably 20 years old which worked a treat but is not to be found anymore, oh well i had just enough to get it all done.
I measured up for the axles today but alko or knott don't make exactly the right size but my welder said if i order one at 1600mm we can cut it and take 40mm out of the axle, is this possible or will that ruin the integrity of the axle, the only other way i have found is to order them specially made from England which would cost a bomb in Transport, maybe i can find them closer to home made to order but my German isn't that good to find such a place!
Old 03-01-2012, 06:56 AM   #32
Dabrowa Gornicza , Florida
Hello Mr Green
I buy alko axles with changed mount bracket position directly from alko dealer
I pay 900€ for set like this
If it's good price for you, I can help you , but you need come to Poland for pick up
I live in Katowice so you have 700km to me.
Pawel002 is offline   Reply With Quote
Old 03-02-2012, 05:30 AM   #33
salzburg , salzburg
Pawel that is really a good price i have been quoted with shock absorbers €1400 without transport! so you are lucky, are your brackets at 1560mm apart?
Old 03-02-2012, 05:55 AM   #34
Yes my bracket is 1560mm and outside is 2040mm
Old 03-03-2012, 03:18 AM   #35
salzburg , salzburg
Well bad day yesterday the owner of the barn wants his space back! and the glass i had cut is the wrong size, luckily they measured up it so they will have to replace it. Luckily the workshop that is doing the frame has space for me and i will atleast be under cover even if it's open at one end but on talking to the welder he's decided a new frame is easier to make than repairing the old one and he's going to teach me how to weld in the process so it's win win and he is going to galvanize the frame as well! can't wait to get the bill for all this but oh well do it once do it right!!
Pawel that is a great price, although i am rating my axles to 3500kg to put the kitchen in there and i geuss there is a difference in price, how long did your order take to make and could you ask what the cost of them would be?, a trip to Poland maybe in my future!! thanks!
Old 03-03-2012, 04:21 AM   #36
I check the price and for 3000kg rating axles they want 1230€ , for 3500kg - 1680€
All price are for sets like on photo on previous post, with changed position of mount bracket.
So if you found for 1400€ it is very good price.
Old 03-27-2012, 12:18 PM   #37
salzburg , salzburg
polishing
Well it's been a while thought i better post an update, I have finally started the frame build I have the base all laid out and the outriggers all cut and ready to weld, i made it out of 24 gauge steel so it's definately going to be strong enough to hold a kitchen!, now i'm just waiting for the axles and coupling to turn up before i finish it and then it will go off to be galvanized ( only a little more than por-15 and no work!!), should be here next week some time fingers crossed, in the meantime i started to polish! holy **** what a dirty job and man does the grey cover alot of blemishes!(scratches) my plan of attack is to hit the whole tub with F7 then go back around removing the stubborn bits of clearcoat and try and sand a few of the scratches out, but if i can get the F7 done before i have to move it (to the body shop) it would be good. attached is a picture of the progress thus far, haven't got one of the frame yet but will post one when finished, the white scrubby marks on the body are from wiping down with white spirits.
Old 04-15-2012, 10:15 AM   #38
salzburg , salzburg
lights?
whilst waiting for my axles to Arrive i've been playing around with my lights (upgrading to e-marked, damned EU regs) well i couldn't find 4" ones so had to settle for these and goo them in a bit but they came out o.k, what i'm really looking for is a set of reversing lights to go into where the reflector sits (as rear reflectors in the E.U must be triangular, you can get round ones with triangular reflectors in them but not at 3") otherwise i'll have to settle for a set of reflectors to fill the holes and i'll have to cut new holes for reverse and fog lights or i'll just mount them under the bumper, choices choices!, on another note does anyone knoe where to get the stabilizor jacks from, I am going to place an order from rvshop.com but they only have the "C"type jacks? are these jacks still available? mine has a 20" leg on it (one missing, one bent!)
My axles should leave the factory on the 17th, my order from Spruce aviation should come Monday or Tuesday so it should be a fun packed week, finishing welding my frame and finally being able to patch the pieces of bodywork which need patching!!
Old 04-17-2012, 10:43 PM   #39
Tool Hoarder
marzboy's Avatar
1965 30' Sovereign
West Hills , California
I got my stabilizer jacks from Inland RV. I love them!! Lookin good!
Behind every great man, there is a woman rolling her eyes.
My Airstream renovation and camping Blog
My frame and floor restoration thread
marzboy is offline   Reply With Quote
Old 05-08-2012, 12:54 AM   #40
salzburg , salzburg
frame welding
Well I've just about got my frame all welded up i just need to weld the outriggers on, the tank holder is two angle iron frames sandwiched together with threaded bar, had problems finding a place for the stabilizers then as the tanks are right in the rear and run 1.5 metres down the frame so the stabilizers are right at the back now and i will make my grey water exit sideways, I managed to get new stabilizers which are rated to 2600kg so I will see how they go as they look very Asian to me!. the steps were another story as they were really rusty so i had them sand blasted and then primed but in that state they cant be galvanized so i opted to weld two outriggers on and then slide the steps onto them and bolt the whole thing together
i will add some more photo's but i forgot my camera yesterday,
Old 05-12-2012, 06:22 AM   #41
salzburg , salzburg
outriggers
Yesterday got all my outriggers on and my steps all sorted to bolt on when it comes back from galvanization, tank holder finished with the hole cut in the right place this time!, originally i cut a hole for it to exit out the back but then it would get caught up on the stabilizers so it now exits out the curb-side. just a few small bits and pieces to finish up and then the first hurdle is finished.
the tanks will hang on threaded bar sandwiched together from these lugs
1963 Tradewind Original Wheel & Tire size?? BurritoWagon 1959-69 Tradewind 20 02-08-2012 02:27 PM
'73 Tradewind on the horizon pxlchk1 1970-79 Tradewind 7 02-05-2012 02:56 PM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
HENSLEY CUB w/73 Tradewind my3sonsdad Hitches, Couplers & Balls 5 08-02-2011 07:31 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
