06-09-2012, 04:16 AM
#21
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by tpi
The Trailer Depot
Here's some good pics of the aluminum floor in the Camplite. I like this trailer for its size, but I'd sure want to cover that floor with something to keep my feet warm. I'd probably stick to it on a cold morning.
And yes I'd surely pay for upgraded floor in Airstream.
Also a little extra for those nice push to release latches on all the storage dorz.
Not sure I could convince the DW that all that inside bare 'lumunum is kool, or maybe it's just too kool. She's still pretty hot after all, think condensation.
Originally Posted by danlehosky
Bob, He backed out, Cold feet. No vision.
Dan
Field testing I think....got some in his I's.
06-09-2012, 06:30 PM
#22
1968 26' Overlander
Duluth
How about this?:
NyloSheet
06-09-2012, 06:37 PM
#23
1968 26' Overlander
Duluth
Tried to post this with a link, but I'm new here so need a moderator approval. Search for Nylosheet for Nyloboard. This looks great for the floor. Made in USA. Recycled material, too! Apparently it also comes in 4'x24' long sheets. You single axle owners could use two sheets with one seam down the middle!
06-09-2012, 08:17 PM
#24
Got you covered.
Kevin
William C. Swinney
06-09-2012, 09:35 PM
#25
1971 25' Caravanner
Olathe
, Kansas
That Nyloboard looks promising! I just wish it were available locally. It seems like it's so new that they don't have distribution set up yet. I am looking to need it in October. I just hope they get set up by then! I'd like to see it without driving to Georgia!
"Surrender is not in our creed. Let me hear you say that..." Gunny Hiway
06-09-2012, 10:50 PM
#26
1968 26' Overlander
Duluth
I wrote to them via the online form and will let you know what is returned. I am certain they would send you a sample.
One could also use recycled HDPE sheet goods. There is a company here that started out using it for skateboard park surfaces and now uses it to make outdoor furniture (loll designs) and some other stuff. It is super strong and essentially weatherproof.
A quick search revealed one online source:
High Density Polyethylene (HDPE) Sheeting | U.S. Plastic Corp.
HDPE 4x8 sheet 3/4" thick is $373.76 on this site.
Does it need to be 3/4" thick? I have been reading a lot of threads here on floor replacement. Some seem to reference 5/8" and others 3/4". My flooring in the '68 Overlander appears to be 3/4". I am not completely certain I understand how the floor/wall/pan intersection goes yet (anybody have a cross section?). Perhaps one could use thinner sheet goods if the specs. meet or exceed the original plywood?
Both of these options (HDPE sheet and Nylosheet) can be cut and shaped with standard woodworking tools and fastened with components similar to the originals. One downside of HDPE is that is is difficult to glue to it.
Seal plywood however you want, it still contains cellulose for microbes to eat and will eventually fail in this application. I think these other two options seem like more durable solutions. Maybe our great-grandkids will be able to go camping without having to do a second shell-off?
06-10-2012, 07:55 AM
#27
1971 25' Caravanner
Olathe
, Kansas
Bunkroom,
I have also contacted Nyloboard and explained what I am doing. Will post whatever they respond. The stuff looks promising, but I only want to do this once! That HDPE stuff is expensive! I will need About 6 4x8 sheets so ouch! I am sure that Nylosheet is no better on price, though. We'll see!
Ken
06-10-2012, 09:42 AM
#28
2012 25' Flying Cloud
Battle Lake
I suspect Airstream uses plywood because it suits the construction better than anything else. The floor rot happens when the water gets trapped under the vinyl and cannot dry out. I would like to see a selection of breathable carpet sections that could be removed for cleaning or inexpensively replaced, no vinyl. Easy to inspect for leaks.
doug k
06-10-2012, 10:01 AM
#29
2008 27' International CCD FB
Bay Area
dkottum, there's Flor. Not sure about breathable, but it's industrial strength carpet, and you can replace a square any time. *Any* carpet as the main flooring in something mean for camping just seems like trouble to me, though.
I hear a lot of talk about the potential of nyloboard, but has anyone actually installed it and travelled for a while with it? I haven't found a single post about that. I'd be afraid to use it until I hear that there aren't any unexpected consequences from real life use. If there are some threads from those who've actually tried it, I'd really appreciate being pointed in that direction.
06-10-2012, 11:18 AM
#30
1968 26' Overlander
Duluth
The thread was started to explore a better floor material. Supposing why airstream uses plywood is not really relevant. They apparently still do not choose to use the highest grade plywood available or to treat it in a way that might make it have a longer service life.
It seems unlikely that anyone has used Nylosheet on their trailer as it is a relatively new product. Ken and I are exploring its feasibility as a substitute for plywood. If you go to their website and look at the photos from their tests submerging it and other composite sheet goods in water you might be as impressed as I am.
The testing results and specifications for all of these materials are readily available for review on their websites or the web in general. These can be compared to the plywood you are planning to use to get an understanding of how they are similar and different.
Ken, the HDPE sheet cost that I posted was just an example, the first one that popped up when I searched. Thinner sheets are cheaper. If thinner would be acceptable, then cost will go down. The furniture I referred to uses about 1/2" thick sheet and it is extremely strong. I just do not know how it goes into the edge at the walls in the Airstream yet.
One place you have all seen HDPE sheet is in newer commercial bathroom stalls.
Here is another link to an HDPE sheet supplier with additional info:
SHEETS AND APPLICATIONS
Two sheets of thinner HDPE or Nylocore with a sheet of high density XPS insulation between them is another possible solution that would give you some insulation as well. Kind of like a thin SIP.
I have used Warmboard in a home. » Warmboard-R » Warmboard Radiant Subfloor » Archive They now have a panel that is 13/16" thick and comes in 2'x4' pieces. It is plywood that has an aluminum surface with imbedded grooves for radiant tubing. There are now on-demand hot water/space heating units that are designed for RV's that could be used to supply the hot water if you wanted a heated floor!
PrecisionTemp.com: For Recreational Vehicles and Boats
06-10-2012, 11:57 AM
#31
Master of Universe
2008 25' Safari FB SE
Grand Junction
Bunk', present subfloor is 5/8", but they have used different thicknesses at different times.
The subfloor seems to do 2 things—one is to keep you and the fridge and bed from falling through to the ground. The other is structural—to keep the shell from collapsing inward. Could the structural part be accomplished another way—stronger cross members and a stiffer lower section of shell? Then the subfloor could rest on the supports and not have to hold the shell apart, but just support the interior and people. This is the way houses work—it is the joists that keep the walls from collapsing inward, not the subfloor (it does help, but is not primary). Maybe a thinner, lighter, waterproof material could be used for the subfloor if Airstream's equivalent of joists are strengthened.
I've never taken one of these things apart, but the connection between the shell, frame and subfloor seem to be difficult to visualize and deal with when replacement is necessary. Can't this be simplified? If the subfloor just rested on the frame, it would be simpler. Maybe it would be easier to isolate water between the skins (leaks and condensation) and provide weep holes.
The edges of the subfloor are very vulnerable to water. Removable flooring will tell you about water on the surface, but not whether it is infiltrating into the edges (or bottom) and rotting from the middle outward or downward.
Nyloboard looks pretty good and I seem to remember it is a lot cheaper than HDPE. Their website indicates it is used in highly stressed boat parts, but are these the same stresses a trailer faces?
Gene
06-10-2012, 12:20 PM
#32
Port Orchard
Originally Posted by CrawfordGene
Different treatments for putting in a new floor and for sealing an old one—
For many years contractors told me Thompson's was a terrible product, but CR recently rated it very highly. But I think you get a more impervious surface with an exterior urethane (spar urethane).
Gene
While I will admit that we live in a fairly dry climate, I would like to offer this testimonial.
We moved here in the summer of 1993. One of the first things we did was purchase a very inexpensive wooden picnic table kit. Before I assembled it, I coated all sides and ends of all the parts liberally with Thompson's Water Seal. In spite of the fact that it is in the shade most of the time and the fact that is gets thoroughly soaked each time the sprinkler system runs, It is still 100 percent rot free including the bottom of the legs. I had originally hoped for it to last a couple summers.
Ken
06-10-2012, 12:48 PM
#33
1964 17' Bambi II
Schererville
, Indiana
You might want to take a look at this thread, where Nyloboard is discussed:
http://www.airforums.com/forums/f36/...lts-88013.html
Becky
1964 Bambi II
1988 Avion 32S
06-10-2012, 05:40 PM
#34
1971 25' Caravanner
Olathe
, Kansas
Beckybillrae,
I just read the whole thread and so far I am still interested in the Nyloboard. Just have to wait and see if the factory contacts me or not. That was the main rub in the thread as I read it.
Thanks for the link, though!
Ken
06-10-2012, 06:01 PM
#35
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
doug k
Doug,
For the inside?
I used this in the trunk,storage compartments and the bottom of the tongue tool compartment.
06-11-2012, 01:30 PM
#36
Master of Universe
Grand Junction
Why go to all that bother Bob? Just leave the bare subfloor where it isn't visible. You can coat it with a spar urethane.
Gene
06-11-2012, 02:18 PM
#37
1968 26' Overlander
Duluth
This thread started as a discussion about sub-floor not floor finish, FYI.
I heard from Nyloboard. Their 3/4" thick material is 2.5lbs. per square foot. So, a 4x8 sheet weighs 80 lbs.
Seems like there are at least two other threads with previous discussions and experiences.
-Mark
06-11-2012, 02:47 PM
#38
Salem
, South Carolina
I am also looking at composite solutions for floor decking. I have sent email (but no reply yet) to this manufacturer of aluminum panels with aluminum and nylon honeycomb interiors. Looks like you can get panel with aluminum on one side and stainless on other which would hopefully eliminate galvonic reactions.
Honeycomb Panel, Aluminum Honeycomb Panel, Aluminum Honeycomb Core Manufacturers and Aluminum Corrugated Panel, Nanocore Panel, Aluminum Honeycomb Core
With the caveat that I am not a PE, I believe the 4mm thick alum clad alum core panels would be all you would need for subfloor. My math a little rusty but believe 4'x8' sheet of 4mm panel weigh somewhere around 22lbs.
Remember please, I know next to nothing about restoring Airstreams.
Russ
06-11-2012, 04:11 PM
#39
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Gene
Gene,
Carpets......gone now.
That would have only protected it on the top surface, the moisture we had was all soaking thru from the end grain. The leeks are sealed the floor still dry, and we are now armed with a moisture meter. SFSG.
Mark,
How do you plan to "finish" your nilo-bored?
06-11-2012, 06:11 PM
#40
Master of Universe
Grand Junction
Will these aluminum boards transmit heat or cold? Is the core some insulator? The tanks are heated by a duct from the furnace or heat strips, but how much heat comes through the floor–probably not much, but just a thought. Would the use of a reflective, thin metal surface reduce or increase heat in the tanks.
If they are 4 mm thick (.15"), and you are replacing 5/8" or 3/4" and you need to make up the space somehow or things will have to be built up to fit where they are supposed to.
And last, everything has a span where it deflects too much. You have to compare this product with plywood and see if there is a difference.
If I had to replace the subfloor, I think wood is still a great product and can be sealed very well. We know it works in this application except for water issues and they can be solved for a reasonable time. It isn't that hard to do a better job than Airstream.
Gene
