03-15-2016, 10:26 AM
#21
1962 22' Safari
Brooklyn
, New York
wondering about how best to seal my re-engineered connection. should i be using putty tape between parts that are getting riveted together? i'm afraid the extra thickness and malleability of the putty tape will weaken the connection, but also want to seal everything as best i can. i'd love some suggestions.
thanks and a more complete update soon...
03-15-2016, 10:55 AM
#22
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Vulcum between pieces and on each rivet.
Hittenstiehl
03-15-2016, 10:57 AM
#23
1962 22' Safari
Brooklyn
, New York
thanks for the reply!
any tips on how to keep the rivet set and bucking bar from getting covered in Vulcum?
03-16-2016, 09:56 PM
#24
1990 34' Limited
2013 27' FB International
Conroe
We wear latex gloves and grab your tools with throw away paper towels.
Keep acetone around with towels to keep everything clean.
03-17-2016, 01:13 AM
#25
1962 19' Globetrotter
1963 19' Globetrotter
Wheat Ridge
In the Globe Traveler project I also thought through how to make a better connection that you describe! My solution was to build a all Aluminum chassis with an aluminum frame and aluminum floor to once and for solve the rot problem. The frame and floor are both welded and Huck riveted together to form a very strong system. The outer edges of the floor are raped and secured with a Modified "y" channel that is riveted in place so that the belly pan skin and side skins and the floor all become one... The result solves many issues and is very strong.
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
03-17-2016, 06:53 AM
#26
1962 22' Safari
Brooklyn
, New York
Wow vinstream that is next level! At what point does a "restoration" become a "reproduction"? Not that that matters at all. Looks like you built an airstream from the ground up! VERY impressed!
03-17-2016, 08:19 PM
#27
Northeastern
, Kentucky
Impressive. What did you use for your aluminum floor?
03-23-2016, 02:01 PM
#28
1958 26' Overlander
Battle Ground
I've been trying to find a way to deal with these issues also. I have a 57 Overlander single axle. I'm ready to lift once the weather gets a little dryer. I think my answer is a combination of the above and a few other things.
First: With the interior gutted I'm going to create a template of the floor out to the edge of the C channel. See Frank's Trailer Works http://frankstrailerworksblog.blogsp...-this-tip.html
Next use that template to create the outside support like Darkspeed (1 1/2" square tubing) and weld it to the frame. My hope is this will make sure I maintain the same "footprint" when resetting the body, with the bonus of separating the plywood floor from this joint.
While the body is off use my flange tool to create the off set to the bottom of the exterior panels that go below the existing C Channel. This allows the panels of the belly pan to slide in between the exterior panels and the new tubing support. (see diagram) I know I can't do this everywhere. I've pulled some of the belly pan off. Some panels don't go below the C Channel. The end caps screw into the plywood so I could attach those to the tubing support. On those panels that don't extend below the C Channel I could add a Z channel between the exterior panel and the C Channel to get the length.
I would blind rivet the top of the belly panels to the new tubing support so either panel can be removed without affecting the adjacent panel.
The downside I see is having to wait and attach the new belly panels after all this and not when I can have the frame upside down.
Welcome your thoughts on this:
03-23-2016, 04:36 PM
#29
1958 26' Overlander
Battle Ground
Attached the wrong diagram.
Frame Floor revision #1.pdf
03-23-2016, 04:45 PM
#30
1958 26' Overlander
Battle Ground
Attachment 259258
03-23-2016, 09:40 PM
#31
1975 Argosy 28
Springville
, Alabama
Matt
03-24-2016, 10:01 AM
#32
1958 26' Overlander
Battle Ground
How did you cut the kerfs in your tubing and how far apart did you space them to match the curve of the channel?
03-24-2016, 11:18 AM
#33
1975 Argosy 28
Springville
, Alabama
Metal chop saw. Every inch or so then weld
Matt
03-24-2016, 11:22 AM
#34
1962 22' Safari
Brooklyn
, New York
57Vintage, thanks for sharing your plans! So from the outside you will see a new piece of trim running all the way around the trailer between the shell skins and the belly pan?
03-24-2016, 02:44 PM
#35
1975 Argosy 28
Springville
, Alabama
I replaced the belly pan and underlapped it at the shell.(originally it overlapped the shell- bad idea) the corner wraps are the only place you can tell I added aluminum Attachment 259309pic if corner wrap new skin
Side view with new belly wrap- you can also see the curved tubing and 4 in extension
Matt
03-24-2016, 02:46 PM
#36
1975 Argosy 28
Springville
, Alabama
Corner wrap with new skin added
Matt
03-24-2016, 10:59 PM
#37
1958 26' Overlander
Battle Ground
Hi Skyclad
Not necessarily. The red line represents altering the bottom edge of the shell if it extends below the C Channel. If the edge of the shell is even with the C Channel I'll add a piece shaped like the red line, but slide it behind the shell piece. It would be like a Z channel you place between two pieces of stacked paneling on the side of your house. It's placed behind the upper shell piece and covers the top edge of the lower belly pan piece. I have both situations on my 57.
In either situation there would be two horizontal rows of rivets. One on the bottom of the shell pieces into the C Channel and one below that to hold the top of the belly pan pieces to the added square tubing welded on top of the frame outrigger. That would be the most visible change.
One additional item I came across this morning that I plan on adding; a drain from the C Channel through the square tubing and outrigger into the belly pan. See post 21
http://www.airforums.com/forums/f36/...-108679-2.html I plan on using aluminum tubing instead of the stainless that perryg114 used. I'm hoping this will minimize damage from any leakage in the ceiling or walls. I don't plan on insulating the belly. I haven't decided on the type of weep holes to put in the belly pan pieces so water doesn't collect against the steel frame.
03-26-2016, 08:23 AM
#38
Wheat Ridge
Originally Posted by rugjenkins
Here is some important info that may shed light on somethings. The most challenging part of the belly/side transition is at the corners of the trailers. The radius varies between 21 1/2 to 23 inches... Basically no two trailers are a like, my guess is that Airstream did not have a real life template until well into the mid to late 60's. Basically the radius corners are floating out in space. This is the reason the post above as discussed by Frank's Trailer Works to make a real life templet is so important. I have seen and others have discussed that "they" have templets laying around the shop from other trailers projects and "they" use these to recreate the radius corners. The problem with this is the side skins then do not match up when reattaching the body to the floor. This is why the four hardest parts to recreate and fit up correctly is the radius belly pan corners. Unless you de skin the entire trailer from the bottom of the windows down to the belly pan there is no way to get a nice snug fit in the corners of your trailer other than the way Frank does the real life templet. (Note: this is why I always replace lower skins of all restorations besides these skins show the most age.) Adding the steel tubing and bending this radius solves some problems structurally but introduces others more cosmetically because of the reasons stated above. If it was me I would take aluminum and bend into shape rather then cut and weld steel, I however come from the school to not connect dissimilar metals. I hope this both helps out your discussion and raises questions on this transition part of the trailer!
www.VINSTREAM.com
WBCCI # 1962
03-26-2016, 09:37 AM
#39
1975 Argosy 28
Springville
, Alabama
I can dig that. The corner wraps are on with no issues and they look great. The reason I went with steel for the radius is because the frame is steel. Preventive measures are taken at the two dissimilar metals. Heck the front tie down is steel to alum. I agree I prefer alum to alum, but the majority if alum trailers have steel Fran and alum skins and the camper are still thriving. Mine is now better than factory, so I should be able to past it the kids in 30 years and they can upgrade it with new gadgets😁.
Money, time and materials available are big factors in my book!
Matt
03-26-2016, 11:49 AM
#40
1962 22' Safari
Brooklyn
, New York
Thanks for adding to the discussion vinstream!
Rugjenkins, what steps are you taking to isolate dissimilar metals?
