Old 10-06-2011, 10:44 AM   #1
Motorhome floor repair advice needed.
Need to replace a couple of sections in my '84 Motorhome soon, and need some advice.
The Original floor looks like 3/4" OSB.
The motorhomes use an Aluminum sheet between the wood floor and frame... not sure or have not seen that mentioned on the trailers.
I was thinking that for simplicity, I would use OSB again, as bar the leaks I had/have, the rest of the floor looks good after 25 years.
Problem is the thickest OSB Home depot carries is 19/32" I think...
Is 3/4 still available, or should I really use ply?
Here is the area I have thats a problem...
Under the rear bed. I still have a small leak, which I think is from the window frame or marker lamp.
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Shattered window in '98 Airstream- advice needed NoMoSOBs Windows & Screens 18 07-29-2011 01:14 PM
Considering a '67 Overlander, Advice Needed hlo Buyer Guidelines 3 06-16-2011 01:56 PM
Advice needed - Cutting new AC in '64... robwok Furnaces, Heaters, Fireplaces & Air Conditioning 4 05-26-2011 11:31 AM
Replacing a Duo-Therm Furnace - 1968 Randy Gates 1965 - 1969 Globetrotter 4 05-01-2011 11:30 AM
