-   -   Motorhome floor repair advice needed. (https://www.airforums.com/forums/f36/motorhome-floor-repair-advice-needed-83372.html)
Keyair 10-06-2011 10:44 AM
Need to replace a couple of sections in my '84 Motorhome soon, and need some advice.
The Original floor looks like 3/4" OSB.
The motorhomes use an Aluminum sheet between the wood floor and frame... not sure or have not seen that mentioned on the trailers.
I was thinking that for simplicity, I would use OSB again, as bar the leaks I had/have, the rest of the floor looks good after 25 years.
Problem is the thickest OSB Home depot carries is 19/32" I think...
Is 3/4 still available, or should I really use ply?
Here is the area I have thats a problem...
Under the rear bed. I still have a small leak, which I think is from the window frame or marker lamp.
https://www.airforums.com/attachments...339ff42151.jpg
