Originally Posted by hoppingviola
Hi there,
I'm working on a '77 27' beauty - did most of the work last winter, including putting brandy new Dexter axles on - had that done professionally, as the price was only $100 more than doing it myself. Thought it was well worth it.
So - pulled into my wintering spot and have noticed that there is a noticeable lean to the left. I'm at a loss as to how to even diagnose what exactly is wrong. What should I check first? How bad is this likely to be?
Thanks for the advice,
Elliot
Many Airstream trailers, in fact, most RV's, will lean to one side or the other, because one side is heavier. Just because it's leaning doesn't neccessarily mean there's really anything wrong with it.
You can check the obvious things, like outriggers poking out of the belly pan wrap, and interior structure components that have poked holes in the interior ceiling.
