06-30-2018, 11:42 AM
Airstream - Other
Knoxville
, TN
I just wanted to fix a water line.
Not sure if this goes here. Being that I started this trying to fix a broken water line under the sink. Well as some might imagine sometimes things are not what they seem. Well I am now pepping the frame for a coating of POR-15 with the hopes (disillusion) of putting a floor down this week.
[IMG] upside down frame by Eric Frye, on Flickr[/IMG]
06-30-2018, 12:33 PM
Sag Harbor
, New York
For everyone's information, Eric's original thread is here:
http://www.airforums.com/forums/f227...ck-183431.html
Kudos for your sense of humor, and great photos!
Having two different threads about the same renovation could get confusing IMO -- FWIW.
Good luck,
Peter
06-30-2018, 06:27 PM
Airstream - Other
Knoxville
, TN
Thanks Peter, I just figure some folks could use a good laugh.
For those interested this was the end of the day. Degreased and metal prepped. Tomorrow we paint.
[IMG] 20180630_200218_resized by Eric Frye, on Flickr[/IMG]
06-30-2018, 06:53 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
I like your work space.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
07-03-2018, 07:59 PM
Airstream - Other
Knoxville
, TN
I got the frame painted with two coats of POR-15 and it looks good. Next step is belly pan. This could be interesting because I wanted to go back with a one piece belly pan and the only material I could find was from a local trailer repair facility and it is .040 thick. Fortunately I only have to transition over the gray water tank at the very back. Old pan rolled up with new material next to it.
[IMG] Pretty painted frame by Eric Frye, on Flickr[/IMG]
[IMG] belly pan by Eric Frye, on Flickr[/IMG]
07-03-2018, 08:03 PM
diesel maniac
Airstream - Other
Tucson
, AZ
hey your garage looks kinda like mine........unfinished projects everywhere! What is that on the lift? In it's stripped down stage it looks like it could be anything from a Camaro to a Pinto???
Brian
07-04-2018, 05:16 AM
Airstream - Other
Knoxville
, TN
It is a Puma GTC. They where built in Brazil in the 60s through the 90s and also in South Africa.
07-04-2018, 05:23 AM
Airstream - Other
Knoxville
, TN
Here it is before I disassembled it.
[IMG] 20141222_111107 by Eric Frye, on Flickr[/IMG]
[IMG] DSCN0478 by Eric Frye, on Flickr[/IMG]
07-04-2018, 04:16 PM
Airstream - Other
Knoxville
, TN
Enough about the Puma, its belly pan time. I rolled out the new one and placed the old one on top of it for measurements. I guess they shrink with age?
[IMG] belly pan time by Eric Frye, on Flickr[/IMG]
I cut the material down to size and got it on to the frame. Who would have thought a .040 pan would be almost twice as heavy as the .024 original pan.
[IMG] Belly pan fitted by Eric Frye, on Flickr[/IMG]
07-04-2018, 04:19 PM
1972 25' Tradewind
Calgary
, Alberta
The water line is really moving forward!
07-05-2018, 09:30 AM
Airstream - Other
Knoxville
, TN
Yep it should hold pressure in a month or two.
07-09-2018, 07:18 AM
1976 25' Tradewind
, Maine to Arizona
Progress Is Good
With 2 threads I am not sure where to put this question.
Here it it.
Please post a picture or detail how you lifted the body off the frame. Specifically the attachment point on the roof. Any buckling? Reinforcements?
My, you are a clever determined craftsman.
Your Argosy could be a twin red headed step child to my 25' Tradewind LandYacht, floor rot and all.
"Talk is cheap, Airstreams are expensive," Wally Byam.
25' Tradewind
'18 Promaster 1500 High Roof
07-10-2018, 08:45 AM
Airstream - Other
Knoxville
, TN
Here it it.
In my other Thread you will see photos of the Gantry Crane set up. On the inside of the camper all you need is a 16 foot 2x6 board. You do need to remove the items that stick down from the ceiling. I did't completely remove my vents so I drilled recesses in the 2x6 to marry with the vent handle stubs. After that it is sloooowwwwllly lifting the shell so you can go back and cut those pesky rivets that you missed. No buckling or reinforcements needed for lifting. If you have a flat surface to put the shell on then you can set it right down on the ground if not you will need to set up something so you don't roll the edges on the high points of the ground.
07-11-2018, 09:08 PM
Airstream - Other
Knoxville
, TN
Quick update. Sorry no picture as no work was accomplished on the frame. I was traveling for my real job the last couple of days. I ordered and receive some 5052H32 Aluminum from AirPartsinc.com for the wraps so this weekend I plan to have that installed and the I may even put some plywood on the top. Weather depending and my parents are moving back to Knoxville this weekend so I may have to drop every thing for them.
08-18-2018, 04:38 PM
Airstream - Other
Knoxville
, TN
Wow time flies. I have been way too busy at work with far to much traveling (work). It really kills the week. I have gotten a few thing done on the frame. Belly pan on, wraps installed, new axles install and frame flipped right side up. Last weekend I bought so 19/32nd plywood which is just under 5/8th and guess what. Go ahead and guess. That's right it is too thick. So I had to take the power planer to the edges. By the end of the weekend I had everything cut and ready to start bolting/screwing it down. That brings us to this weekend and weather reports Friday said 80% chance of rain Saturday and Sunday. So I didn't even plan on any out door work. By 6:30 pm we had exactly 0.00" of rain. We will have to see what tomorrow brings. Of course I will be out of town for the next month so I don't expect to accomplish much. Here are some pics.
[IMG] Belly pan inplace by Eric Frye, on Flickr[/IMG]
[IMG] Getting ready to flip by Eric Frye, on Flickr[/IMG]
[IMG] 20180725_195242_resized by Eric Frye, on Flickr[/IMG]
[IMG] TV wiring by Eric Frye, on Flickr[/IMG]
[IMG] deck1 by Eric Frye, on Flickr[/IMG]
[IMG] deck4 by Eric Frye, on Flickr[/IMG]
