Old 08-31-2014, 07:02 PM   #1
jcawley1's Avatar
1969 29' Ambassador
Rutledge , Georgia
Frame Rot - New Frame
I have been slowly working on a shell off restoration of a 29 foot 1969 Ambassador Airstream. I have the odd habit of taking on labor intensive projects over Labor Day weekend. Two years ago, I thought it would be a good idea to lay 9 pallets of sod. I am surprised my family still talks to me after that stunt. So this weekend, I thought it was time sand blast the frame of the Airstream. Well, two days into the blasting, I had to come to the inevitable conclusion there is not enough metal left on the frame to save the frame. Suggestions for frame building?
jcawley1 is offline   Reply With Quote
Old 08-31-2014, 07:49 PM   #2
millertimeUS's Avatar
1976 25' Tradewind
I found a local welder and they used my old frame as a template to make a new one. I had new axles delivered right to their shop along with new shocks and a new jack. Gave them POR15 and had it painted as well. Took about 2 months to get back but looks great you can see it just search for "millertime's 1876 Tradewind floor rot " thread.
Matt
millertimeUS is offline   Reply With Quote
Old 09-01-2014, 07:35 AM   #3
jcawley1's Avatar
1969 29' Ambassador
Rutledge , Georgia
I was thinking about that. I have new axles that are under the current frame and can be transferred. In my ambassador, the duct work for the heat ran through the openings in the cross members. Looks like I can get the cross members online but they are not cheap. What did you do for your cross members?
Old 09-01-2014, 08:30 AM   #4
1976 25' Tradewind
My ducting was all above the floor, but your welder can cut or you can cut those holes as needed afterward. I told my welder where I needed holes and gave measurements and he cut them for me. Making the crossmembers out of solid steel angle iron will be much stronger than your original crossmembers with all the holes in them. I recall reading Airstream did that to save weight since passenger cars needed to pull the trailers. With modern trucks we can handle the weight increase so why not beef it up a little?
Matt
how much rot is too much rot? adwriter73 Repairing/Replacing Floor &/or Frame 56 02-28-2010 11:05 PM
how to check for frame rot ? oldvws Repairing/Replacing Floor &/or Frame 28 03-02-2007 07:37 AM
Rust Rot in the Rear Frame Bumper Area HamiBambi Bumpers & Bumper Storage 13 09-19-2006 01:40 AM
"Frame rot" 23' airstream land yacht????? gjkkbberg Repairing/Replacing Floor &/or Frame 5 03-14-2005 05:58 PM
To rot or not to rot. Charming Wino Repairing/Replacing Floor &/or Frame 15 03-01-2004 10:39 PM
